I had a Laserline 860 Alarm/immobilser on the bike when I bought it, it was wired in to the loom in 2 ways, 3 wires to the indicators (left, right and earth) and 4 wires to the loom, one going to earth at the reg/rec, 1 in the black/brown wire for the rear brake light, and 2 to the green/red coming from the starter relay. The green/red had been cut completely in half and then a wire from the alarm to each end.
When the alarm packed up and started not disarming the only thing that stopped working was the starter switch, everything else was fine, all of the lights, horn etc. The block connector on top of the relay was totally ruined and had to be destroyed to get it off. I have since repaired all of the wires, and fitted a new block connector, and on turning the key I have.....
....nothing, not a peep. I've checked it's not the ignition switch by fitting it to the CBR, and it works fine, so can only assume that something horrific has happened to either my battery or wiring elsewhere for this to happen, all of the fuses are fine, so I'm not too sure what the problem could be =/
