nc30 lights dipping up and down
- geebus
- Bike owned: 1990 VFR400 NC30 + SV650s
Hey folks, i seem to have a problem with my dip beam lights.
I very often ride to work and back in the dark through town, so only using dip beams.
My problem is that sometimes my lights appear to dip even further than they should...then get brighter all of a sudden, but not to full beam...just normal dip beam.
I did have a problem with my rectifier a while ago, and back then i thought that was the problem. But it's been sorted for a while. I checked all of my fuses, nothing wrong there.
Full beam appears to work fine, but i've not been out anywhere in a while in the dark to check them.
Any ideas?
Any ideas?
- thunderace
- Bike owned: R6, YZF600R
Re: nc30 lights dipping up and down
Sounds like a voltage regulation problem.
- geebus
rectifier on the way out you think?
- geebus
looked through the Haynes manual (page 9.5 section 6) and it's pointing me to the relay switch. Apparently it should click?
Edit: it appears to be clicking.
BUT...the bike seems to have been converted to the uk spec relay. i suppose for a brighter dip beam?
- thunderace
The original spec would have been 35/35w bulbs, UK spec is 55/60w. That will be why a relay has been installed.
Sounds like the reg/rec could be failing. Is it an OE spec NC30 one? You may be better off replacing it with an 03-05 R6 reg/reg.
- geebus
I assume it's an original one. not really paid much attention to it tbh.
will need to look into it further before i just go and buy a new one.
You get old bikers and bold bikers, but no old bold bikers
Dynamohum
geebus i have a spare o/e rectifier you can have for free if you pm me to arrange collection or can post it to you . would allow you to see if thats the cause of your problem. in any case as thunderace said best option is getting a 5 pin yamaha regulator .
- geebus
oh you're in glasgow too?
That would be quite good. PM me your phone number mate.
