Stick coils. Neo, you out there lad?
Right so we know CBR600rr stick coils work on NC24's with 10mm plugs so would i be right in thinking they would work on NC35's with 10mm plugs? excuse my lack of electric knowledge :oops:
So for ebay purposes what part of the cbr loom do i need?
skinnydog0_0
Bike owned: Penny Farthing
Re: Stick coils. Neo, you out there lad?
Post by skinnydog0_0 »
I think this kind of explains what you are after Tony, i have been thinking about this mod too :grin:
Might get round to it in the summer.
viewtopic.php?f=24&t=22111&p=153540&hil ... ck#p153523
cheers fella, so from that i think its pretty safe to say they should work and as i have 10mm plugs fitment shouldnt be a problem. Off to ebay i go :grin:
skinnydog0_0
haha, yes give it a go :grin:
10mm plugs, is that with screw caps or are they different plugs altogether?
just normal plugs mate but 10mm
You have got your heads helicoiled for the 10mm though haven't you mate? They are not 10mm plugs in standard plug threads..
I think Jeff was thinking getting his bad self some of these... ;)
Heads have been drilled and re-tapped by the looks of it. Plugs are NGK twin tipped, cant remember the number but they use them in R6's i think.
What benifits it gives i dont know, bigger spark bigger bang i guess? but its trick so i like it :grin:
Variablevalves suck
Post by Variablevalves suck »
Hi guys ive got sticks on the Suzi and they really work well and are a little smoother at the top. The honda loom is wired up in parallel and this needs to be altered so you connect the wasted pug pairs in series. If you wire it up wrongly it will over heat due to the current flow in the wires- if you wire in parallel you will get 16amps across the coil instead of 4amps in seies. They dont seem to work for every bike and i know of people who have had problems with hot starting so lump it and see.
skinnydog0_0
CMSMJ1 wrote:You have got your heads helicoiled for the 10mm though haven't you mate? They are not 10mm plugs in standard plug threads..
:lol: How did you guess Mark :lol:
Just out of interest Tony, have you had to make any carb changes to allow these plugs, do you need to burn more fuel?
Variablevalves suck wrote:Hi guys ive got sticks on the Suzi and they really work well and are a little smoother at the top. The honda loom is wired up in parallel and this needs to be altered so you connect the wasted pug pairs in series. If you wire it up wrongly it will over heat due to the current flow in the wires- if you wire in parallel you will get 16amps across the coil instead of 4amps in seies. They dont seem to work for every bike and i know of people who have had problems with hot starting so lump it and see.
Hi Chris If i wire them up as per Neo's thread would i get 4amps at tick over? or is only on a load?
Variablevalves suck
Hi Jeff, its simple ohms law, the standard coils are about 3 ohms and the stick are 1.5 so if you wire in series you add them 1.5+1.5 = 3 and then 12v / 3ohms=4 amps.
In answer to Tony's twin electrode plugs they are that way so the spark plug does not need indexing (plug shimmed to make electrode face the inlet). :peace:
