wont start
zalanz
wont start
Any clues?
Have had battery on OPTIMATE for 2 months now. But have not started the bike.
I tried today but it did not even fire!
What advice can anyone give me, as I tried until I flattened the battery. 2 months ago it was absolutely fine
hardnutdvd
- Bike owned: RVF400 NC35
Re: wont start
might be worth gettin the battery tested. have you a multimeter?
have you tried bumping it? pain in the arse but it can be done. once it is running you can check its receiving charge and holding it.
the following guide may help
http://www.electrexworld.co.uk/pdfs/Tro ... G-&-RR.pdf
Re: wont start
use choke and no throttle... if you have bene winding it on then get the plugs out and dry them.
trry again..if no joy..new plugs time
hardnutdvd
Re: wont start
ah, i was assuming when he said not firing he meant nothing happening on the press of the button
zalanz
Re: wont start
It was a new battery last summer
I was just surprised it did not even attempt to fire.
Its back on the Optimate so will try again in a day or 2
thanks
It would not hurt to jump start it to a car battery would it?
thanks
- alexwitham
Re: wont start
I have always been under the impression this is not a good idea, I may be wrong though.It would not hurt to jump start it to a car battery would it?
- hallsie
- Bike owned: NC29
wont start
I thought a car battery whacked too many amps through cos you can't use a car battery charger on a bike battery without killing it I think , someone correct me I'm wrong though !alexwitham wrote:I have always been under the impression this is not a good idea, I may be wrong though.It would not hurt to jump start it to a car battery would it?
kate beckinsale....... mmmmmmm
Delboy
Re: wont start
I use a car battery charger on mine, usually ony flick it on for a few hrs at a time just to 'keep it topped up' so to speak
Last year the winter killed a new battery, this year all has been well......... so far
- thunderace
- Bike owned: R6, YZF600R
Re: wont start
The bike's electrical system will only draw the current it needs from a car battery. The only reservation is that the car should not be running while jump starting a bike due to possible over-voltage damage to the bike's electrical system.
Re: wont start
thunderace wrote:The bike's electrical system will only draw the current it needs from a car battery. The only reservation is that the car should not be running while jump starting a bike due to possible over-voltage damage to the bike's electrical system.
as an electrician,
current is something you take not give,
voltage is something you give and not take,
capische?
and i used a 12V 95AH battery in my garage for starting, jumping, testing shit etc it stays fully charged for months!
