Replacing NC35 with NC30 Carbs
Re: Replacing NC35 with NC30 Carbs
Banoffee you know me too well, i guess this wont fit a NC30? but a dremmel and me work well together dont you know!
may be worth the punt based on the chrome oil filter!
karl BKK
swapping the carbs out or setting them up (as i'm sure you know) won't make it any faster, unless it's currently running really rough and/or you replace the exhaust....? It's just get the bike running how it ought too.
I'd buy 14t front sprocket if you really want so get up and go from slow speed corners, taking the right route with the brakes, i wish i could find a set up like that here in Thailand.......
- Cru Jones
- Bike owned: NC35
If one was to race the NC35 wouldn't you swap out the carbs for the NC30 carbs? Aren't the NC30 carbs better on the top-end? Has anyone done this?
edit: nvm - this thread answered my questions - viewtopic.php?f=24&t=18525
On a side note the built in search for the forum is well, less than helpful.
I had to search the whole forum via the Google to get any search results for "nc30 carbs on nc35." The search via the forum gave the below response.
Information
The following words in your search query were ignored because they are too common words: nc35 carbs nc30 on.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 12 characters excluding wildcards.
Information
In general yes 30 carbs for race and 35 carbs for the road. You don't need the user friendly ness of 35 carbs when your living above 7k constantly.
- skinnydog0_0
- Bike owned: Penny Farthing
Yer i know what you mean, i had this problem at first. It is easier to search for topic titles only; you get a much better response.Cru Jones wrote:If one was to race the NC35 wouldn't you swap out the carbs for the NC30 carbs? Aren't the NC30 carbs better on the top-end? Has anyone done this?
On a side note the built in search for the forum is well, less than helpful.I had to search the whole forum via the Google to get any search results for "nc30 carbs on nc35." The search via the forum gave the below response.
Information
