NC35 Bolt on Brake upgrades..
XXXV4
Bike owned: NC35 RVF400
Post by XXXV4 »
Hi all,
Anyone know of any bolt on brake upgrades (from a factory Honda) from say a bigger/newer bikes like a 600 etc, that will fit up without (too much) hassle? Im Not afraid of doing some custom fabrications, Just lazy enough to not want to have to modify too much to get some bigger anchors :)
Any threads or links appreciated!
cheers guys.
Re: NC35 Bolt on Brake upgrades..
XXXV4 wrote:Any threads or links appreciated!
cheers guys.
did you not find any in a SEARCH then? ;)
CBR6RR/SP1 and brembo's are a easy option, google rick oliver while your at it for his price list of NC parts and conversions.
Post by Evilchicken0 »
New reg rec.
a company SES probably do rearsets for it.
change the reg rec
Get the suspension rebuilt and properly setup
then change the reg rec
XXXV4
Post by XXXV4 »
cheers guys.
try search "nc35 brake" on the search panel... go on.. i dare you :) but yeah thanks for the info ;)
You have to be a bit more specific with searching, its good but its no mind reader :grin:
Try "nc35 caliper upgrades"
hannakournikova
Bike owned: NC30, NC35 & SP2
Post by hannakournikova »
XXXV4 wrote:try search "nc35 brake" on the search panel... go on.. i dare you :) but yeah thanks for the info ;)
Im with you there!!
CRM
Admin NWAA
Admin NWAA
Post by CRM »
The following words in your search query were ignored because they are too common words: brake nc35.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 12 characters excluding wildcards.
Ok this gets asked often. I know the phpbb search backend can be a bit hard work, however it is only as good as what's entered. now funnily enough NC35 is actually quite common believe it or not, same goes for brake. now i know this may be a bit of a long shot, but if you coupled the same search with upgrade or cbr600rr which is mentioned all over the place, the search gets narrowed down.
common sense really
XXXV4
Post by XXXV4 »
"nc35 brake" wasnt the only search i tried if it wasnt hard for you guys to find an alternative seach keyword for me, im sure it wasnt hard for me.. :)
but yeah i had read/heard rumours that 600rr ones fit just wanted to know if it was a straight bolt on or if a bracket was needed... and from research it seems that a bracket is needed.
Thanks again guys..
and just so you know i wasnt being a smart ass, just seeing the funny side of it!
Enjoy..
600rr calipers on NC30 needs custom brackets
600rr calipers on NC35 is a direct bolt on ;)
Hope that helps
XXXV4
Post by XXXV4 »
Drunkn Munky wrote:600rr calipers on NC30 needs custom brackets
Hope that helps
ooO :) yipee! eBay here i come... lol thanks!
guess i should gert the master cyl. aswell... hmm maybe some braided lines too.. :)
what about rears? is there anything that can be done there?
