nc30 types?
jaynhl
nc30 types?
Question is there a way to determin which type your nc30 was orginally? Maybe you can use the vin number or as you guys might call it the head stock number. My bike came with aftermarket fairings on it and im looking to restore it to 100% orginal and i'd like to attempt to figure out which type/color combo my bike was orginally. Any help would be great. I know here in the states on old antique cars and such you can decode the vin numbers so to speek and figure things out. For example i had a 57 chevy belair and from the vin i could tell what the build date was, number off the line, plant it was made in, orginal motor, orginal options like ac and what not, interior and exterior colors. All that you could figure out from the couple numbers on the car. I'd like to do the same with my nc30.
Jason
Jason
arsey30
- Bike owned: ftr223 650 bros
Re: nc30 types?
Look under the pillion seat, there should be a white vinyl label on the fender with a paint code e.g NH ----.
Dave.
Dave.
jaynhl
Re: nc30 types?
ya i have that sticker problem is its in japanese and i cant read it... plus i dont know if that is the orginal undertail and sticker or not so i was hoping to be able to figure out type from the stamped on numbers cuz i know they havnt changed lol. so is the only way to figure out type of nc30 from that sticker on the undertail or does anyone else have any ideas?
Jason
Jason
- ibby4585
- Bike owned: SP's
Re: nc30 types?
Google ' nc30 model info' and work it out from that! The Headstock number should correspond with a year and colour scheme
jaynhl
Re: nc30 types?
ok by doing that i came up with mine is either a r3l or r3n. not sure which one as of yet have to do alittle more reasearch. but either way it still gives two color codes for each of them. so is there a way to break it down even more and figure out which of the two color codes for either the r3l or r3n my bike could be??? any ideas? im really up in the air which which of the type color combos i like so i figure if i can find out which mine was orginally then thats what im going with.
jason
jason
Re: nc30 types?
This sticker is the only way to tell what the original colour scheme was.jaynhl wrote:i was hoping to be able to figure out type from the stamped on numbers cuz i know they havnt changed lol. so is the only way to figure out type of nc30 from that sticker on the undertail or does anyone else have any ideas?
jaynhl
Re: nc30 types?
can anyone here decode japanese if i post a pic of the sticker??? Then i guess i just have to hope that is the orginal sticker/undertray.
Re: nc30 types?
This link shows the 8 nc30 colour schemes and the colour codes.
Some used the same code, so you need to know what year model you nc30 is (frame number & haynes manual), then check which scheme it is:
http://www.vsource.org/VFR-RVF_files/Bvfr400r-mi.htm
arsey30
Re: nc30 types?
jaynhl wrote:can anyone here decode japanese if i post a pic of the sticker??? Then i guess i just have to hope that is the orginal sticker/undertray.
Post it up, this is the one I mean, are you looking at the right sticker, there were 4 on my fender.
The paint code label and year model on mine were printed in English, not Japanese.
Dave.
jaynhl
Re: nc30 types?
where exactly is that sticker located??? u said fender so im assuming you mean undertray or undertail right under the rear seat is this correct??? let me know and i will look again but i think i remember someone telling me to look there awhile back and i did and the only sticker i found was in jap... but let me know for sure where that sticker is and i will double check and post my findings...
thanks
jason
thanks
jason
