Standard CDI vs Ignitech Programmable CDI - Dyno Results
- banoffee
Re: Standard CDI vs Ignitech Programmable CDI - Dyno Results
Nice one. How do they compare to the 'original' HRC map? Am running that with shell v-power or similar and it seems to go like a rocket. Not sure if the fuel makes a big difference but the combination 'seems' to work well. Mine is stock other than the CDI, race can and jetting.
- alexwitham
I prefer the HRC-2 and the improved standard maps over the original HRC (improved standard is what im using). However i would have thought if you had a bike like Dm's RLR stage 3 RVF, the Original HRC would be the better out of the 3. It really depends on the state of engine tune.
I use v-power fuel in my NC's as it seems to burn better/cleaner, whether thats a fact or not but lets not go there
Maybe contact Rick and get the settings/file for the improved standard or HRC-2 and see what you think?
Alex
Alex
- banoffee
Cheers. Already got both, will give them a go.
- banoffee
Been running the HRC-2 map for a while now. Had adjusted the redline to 14,500 and also tweaked the tacho output so that it's more accurate. One of my fave upgrades on the bike
- alexwitham
Great mod imo.
