NC30 - K - Clutch Cable
pugparcels
Re: NC30 - K - Clutch Cable
Post by pugparcels »
i was a bit confused when the new one i bought was longer than the old one, but i was not going to worry until i was about ready to mot her, thats now about 2 weeks away so i need to get my act into gear as well!
will have a look once i get back tonight, i will emasure the lengths as well for you.
chris
porndoguk
Post by porndoguk »
Hello,
Thank you for your email.
Please look at the attached page from the Honda parts book .
You can clearly see that your R3K model uses a different part no to the other R3L & R3N models.
So they do NOT use the same cable though the range.
Since your phone call i have found out a dealer that has the correct cable in stock (22870MR80000) so i have ordered it for you .
Please return the wrong cable for exchange.
Kind Regards
Keith
Thank you
David Silver Spares Ltd
Post by Neosophist »
Even if Honda don't make one anymore you can still make your own clutch cable if you need to, buy the ends and some inner / outer cable and make it to suit.
Although that cable is actually longer than your strange red one, it looks like it should work
If you pull the clutch inner cable all the way forward from one end on each cable and see how much cable 'slack' you actually have, they look about the same, which means that when the cables clamped up (granted its longer) you still have the same throw on the cable.
If the new one has an extra inch of cable sticking out then it's obviously not going to work as the clutch cable wont pull that much.
Honda probably changed the routing on the clutch cable which is why the later one is longer. I should imagine the throw on it would be the same though as they all mount in the same places at the clutch end and from what I can remember and afaik use the same clutch lever.
Did you try the cable rick?
porndoguk
Post by porndoguk »
when i tried to route the cable differently and tightened the adjuster to the most tightest it still didnt engage the clutch fully as the internal was longer im convinced this has been packaged wrongly as the part numbers DONT match.
and tbh i wasnt happy with it, i felt i was better off with the wank over stretched old one :shock:
BillingCBR
Post by BillingCBR »
People make mistakes bud, if it's been packaged wrong that just makes it harder, especially with these grey imports ;) They've offered you a replacement, so they can't do any more for you :up:
porndoguk
Post by porndoguk »
BillingCBR wrote:People make mistakes bud, if it's been packaged wrong that just makes it harder, especially with these grey imports ;) They've offered you a replacement, so they can't do any more for you :up:
im not moaning, its sorted and dealt with but my point was this morning DSS didnt seem to wanna help me. but they changed this afternoon?
