76a cylinder head gasket
				donk
- Bike owned: Gk76a x2
hello im havin a valve clearence check done somtime over the winter by a local dealer i've had to supply a new gasket for them because they dont want the issue of ordering parts for the bike ive just got the gasket genuine from elsewhere suzuki part no 11173-30b02 does anyone know if its supposed to have a break in it or be one continuous gasket (i have a break in it) any help would be much appreciated many thanks
				prelude_stealth
- One Hit Wonder
Re: 76a cylinder head gasket
what do you mean break? can you post a pic? close up preferrably?
				donk
its a rubber gasket that has a join in it its not all moulded in one piece a bit like if you were to cut an elastic band then try to join it back together  ill try to get a picture on tomorrow so you can have a look cheers
				donk
Here's a picture, it has a join at the top
Many thanks
						Many thanks
- Variablevalves suck
Hi Donk,
As far as i know it is one peice, ive Gk73a and Bandit4 ones which are one peice, They all share the same part number.
				donk
thanks for your reply i'll get on the phone tomorrow to see if they can sort it out and get another thanks again
