35 rear sprocket nuts - size ?
- CRM
Chaps, want to replace all my tatty sprocket nuts on my 35. what size are they ? M12 ? i am rubbish at this kinda thing. i know they take a 14mm socket and are the same as my old CBR600RR shock and linkage nuts if i recall.
Ta
Ta
- thunderace
- Bike owned: R6, YZF600R
Re: 35 rear sprocket nuts - size ?
The thing to remember is that the Japs do head-to-thread sizes differently to us normal peeps. For instance, they don't use anything 13mm, it's 12mm instead.
IIRC, a 14mm head on a bolt in Jap terms is an M10 thread and most likely 1.5mm pitch
EDIT: yes that's right, it's 1mm smaller than UK size, ours is 15mm for an M10.
- silentRVF
- Bike owned: NC35
Sorry can't help with sizes but this may save you time trying to find out what size they are, and then save you a trip to a fasteners shop?
http://cgi.ebay.com.au/HONDA-VFR-RVF400 ... 500wt_1156
They do do some things a bit different, but there are several 13mm bolts on the nc's!thunderace wrote:The thing to remember is that the Japs do head-to-thread sizes differently to us normal peeps. For instance, they don't use anything 13mm, it's 12mm instead.
arsey30
- Bike owned: ftr223 650 bros
The original are M8 flanged locking nuts with 14mm head, but the latest type have a reduced head size.
The washers are extra thick, but don't buy genuine, at £2 each.
Dave.
Dave.
- CRM
lovely thanks guys. i have no idea about this M stuff, so got some on ebay cheers.
Metric Bolt Head Size.. very useful.
This is printed out on my wall in the workshop.
You want to look at the Bolt Size (Which is the M size, i.e. M8) and then look at the JIS (Japanese Industrial Standard) to get the bolt head size.
As you can see, an M8 has a 13mm head in ANSI (American) and DIN (German) sizes, but a 12mm JIS size (which is what our beloved Honda's use.)
- CRM
Top marks, makes it simple indeed. easy to stock up on stainless now. cheers for that
paul give my guys a shout at wella fix see what they can hook you up with seem reasonable on prices!CRM wrote:Top marks, makes it simple indeed. easy to stock up on stainless now. cheers for that
http://wellafix.co.uk/default.aspx
