Gixer rotor conversion?
- Variablevalves suck
Re: Gixer rotor conversion?
Standard flywheel is 1820g.
- micpec
marcus57
micpec wrote:1820 minus 618 saves 1202 grams (that is only the flywheel/rotor mass). It is on my list, must need a kit.
- Scotch Skeleton
- Bike owned: Your Mum
Variablevalves suck wrote:Standard flywheel is 1820g.
Re-record not fade away
zebulon
jeeeeeesesssss, I thought my to-do-list is getting shorter
gonzothegreat
another thing to add then...
- skinnydog0_0
- Bike owned: Penny Farthing
Right, got the bike back together and took it for a blast today.
I didn't really get the best from it, as i reckon it needs up-jetting. I currently have 110s in and it struggles about 3k before the red line. I was thinking that perhaps i should use 115s, anyone got any thoughts?
it's an NC35 with a race can.
I run 116 dynojets in a set of 35 carbs I have for my rvf, haven't tested them extensively yet but all seems fine. The carbs also have 1mm needle washers and hrc springs.
- skinnydog0_0
Cheers DM,Drunkn Munky wrote:I run 116 dynojets in a set of 35 carbs I have for my rvf, haven't tested them extensively yet but all seems fine. The carbs also have 1mm needle washers and hrc springs.
Are they dynojet or another type of jet you use? I have the 1mm washer but not the springs. I might see if Rick O would do the springs on their own.
Yes dynojet jets available from rick as to are the hrc springs on there own
