Drilling Slide Advice / Pilot Screw Query.
Re: Drilling Slide Advice / Pilot Screw Query.
724 are a later revision and probably the only ones about.. there was a full set of brand new ones on ebay recently :OYakama wrote: Does anyone know which NC24 carb slides have the curved bottom mentioned above as there are two different part numbers according to microfiche:
16111-ML0-724 & 16111-ML-0004
cheers
Are you planning to order new ones as there 115 each IF you can get them 460 is awfully expensive.
- superlite
- Bike owned: TLS, LB80 x 2
After eagerly putting my hand up for some HRC slide springs, I realised that HRC don't have a part listed for slide springs for the NC30? At least, I can't find any part numbers? Am I dreaming here? I've had some very dodgy springs in HRC equipped carbs in the past - are the springs you have the the real deal RickRickOliver wrote:I`ve managed to get my hands on some NC30 carbs which have HRC slides and springs in them.Rick
'Take it to the Back'
- Yakama
I just want to know to see if I can source any cheap ones and also to see if its the early ones or later ones that are like the HRC slides.Neosophist wrote:724 are a later revision and probably the only ones about.. there was a full set of brand new ones on ebay recently :OYakama wrote: Does anyone know which NC24 carb slides have the curved bottom mentioned above as there are two different part numbers according to microfiche:
cheers
They should be both the same.. 724 means a revision over the base part, so not sure what was changed.
I'll have a look in the parts book later on see what it says.
- Yakama
