cheers
Pete
From what I remember Rick you just have the de-restrictor box, this doesn't change the RPM's on the bike as the rev limit is controlled by software in the ECUrickyb_dj wrote:erm, chances are it will be,
however, i have an HRC CDi on mine that allows it to rev freely up to 15.5k RPM
where the jap imports rev upto 14.5k RPM
also i think there restricted speed wise, and i guess your best bet it get on the motorway and i think the speed limit is 80mph? or maybe 120kph? i cant remember.
Rick
the standard jap CDI is limited to 14.5k RPM, where as and new CDi or HRC, Ignitech ones raise the RPM and extra 1000RPM,ibby4585 wrote:I'm confused about this Ricky. I think there is only a speed restriction , Not sure about the rev limiter. All I do is fit a motrax blue convertor so it doesn't hit the kph limit!
I'd be interested if this is wrong!
Kris
I can assure you that you don't have an HRC CDI, but probably an HRC deristrictor box. The difference is: One is virtually non-existent, and the other is common but goes for non-existent pricesrickyb_dj wrote:i have an HRC CDi on mine that allows it to rev freely up to 15.5k RPM
http://cgi.ebay.co.uk/Honda-VFR400-NC30 ... 51946829acHONDA VFR400 NC30 GENUINE HRC Ignition Unit. Also known as HRC Chip.
Comes complete with CDi unit.
Removes all speed restrictions and restores mid range dip in power for noise regulation tests.
No longer available from Honda.
A CHANCE TO OWN SOME GENUINE HRC KIT
FAST BECOMING A VERY RARE ITEM
VERY SIMPLE PLUG AND PLAY INSTALLATION
INCREASES THROTTLE RESPONSE
INCREASE RPM LIMIT
Only selling as no longer have my VFR400.
Honda VFR400 NC30
Remaps ignition
Raises rev limiter to 15,000rpm
Increases mid range power
All parts are used, so please expect usual marks & wear and tear. If a part is damaged it will be listed as such and priced accordingly
sorry i wrote that out wrong, i have the HRC box plugged into my Standard CDI, and it does increase RPM, when removed my bike only goes to 14.5K RPM, with the HRC plugged in the RPM goes to 15.5K RPM,superlite wrote:I can assure you that you don't have an HRC CDI, but probably an HRC deristrictor box. The difference is: One is virtually non-existent, and the other is common but goes for non-existent pricesrickyb_dj wrote:i have an HRC CDi on mine that allows it to rev freely up to 15.5k RPM![]()
The HRC deristrictor box allows for full speed, but doesn't increase the rev range (why would you want to!).
