NC30 clutch issue
Smoky
NC30 clutch issue
afternoon all, just though some of the more learned amongst us may be able to shed some light on this situation.....
just had my clutch plates changed (friction and steels) for a second hand set in good condition- when clutch was rebulit there was tons of freeplay on the lever and now feels as if the springs are much tighter.
this in turn has reduced teh size of the biting point, so that the clutch is now more of an "off on" switch.
pulling away in first without stall or crunching the gearbox is exremely tricky when before the change it was fine.
i changed the plates because the clutch was slipping quite badly, and did find a couple of dead friction plates when i took it apart...
when i start the bike from cold there is not much freeplay in the lever, but after a few miles the freeplay keeps increasing, so i have to adjust it at the lever end on the fly....
anyone come across anything like this before?
Smoky
Re: NC30 clutch issue
wow- no one?
thats a first...
thats a first...
lol.. patience...
err..but no, does the feeling come back when the bike is cold?
The clutch is a pretty solid bit of kit - you pull the lever, pulls the cable, turns the rod, pushes the actuator, opens the pressure plates.
Nothing in here is soft enough that it will become affected by heat?
Loose cover? loose clutch nut? dodgy cable?
Erm
Your post doesn't make much sense.
If they are fine it then sounds like it isn't assembled properly.
Heavy duty / stiff springs shouldn't make the biting point on an off, just make the clutch lever harder to pull in.
If your clutch cable needs to made tighter to operate the clutch as it is warming up it sounds like it isn't assembled properly.. at first i thought knackered clutch plates but I don't think they'd require the cable to be tightening up, although it could be both.
I'd really take everything back apart and follow the microfiche through when rebuilding everything.. having somone with you who doesn't speak bike might help, so long as they can read the pictures it helps when your putting things back together as they often catch mistakes someone technical wouldnt..
It sounds like your new old clutch plates are knackered if the biting point is an 'on/off' feel. Did you measure the new old plates and friction disc thicknesses before you built it?condition- when clutch was rebulit there was tons of freeplay on the lever and now feels as if the springs are much tighter.
Something seriously wrong here.when i start the bike from cold there is not much freeplay in the lever, but after a few miles the freeplay keeps increasing, so i have to adjust it at the lever end on the fly....
Smoky
the tension comes back yes- but the clutch it still very snatchy...err..but no, does the feeling come back when the bike is cold?
cover is on tight, clutch nut set to correct torque setting- cable is fairly new....Loose cover? loose clutch nut? dodgy cable?
mechanic measured them for me and said all was good...It sounds like your new old clutch plates are knackered if the biting point is an 'on/off' feel. Did you measure the new old plates and friction disc thicknesses before you built it?
lever isnt any harder to pull in, just seems like the tension from the springs comes in all at once...Heavy duty / stiff springs shouldn't make the biting point on an off, just make the clutch lever harder to pull in.
clutch plates looked ok to me before they went in, and the mechanic who built the clutch has done work for me in the past and was spot on- but i suppose it could have been assembled wrong...Something seriously wrong here.
thanks for the replies gents- am getting the mechanic to open it up and have a look this weekend so will let you know how it goes.
cheers!
Springs come on all at once...
Strange explanation but you mean there is no slippage of the clutch? It's either engaged or disengaged.
Worn plates can do this as well as incorrect assembly, or both.
People put extra springs / plates in there.. i'm sure Mark will have some more info about this.. :)
Smoky
pretty much, yeah. to get a smooth pull off you need to be MEGA careful with the lever as the biting point is so narrow.Springs come on all at once...
the plates that were removed were well past their day- two of the friction plates were almost smooth- but even then i could still get a decent biting point- just no full throttle as it would slip
cheers-
I reckon it has been installed incorrectly. How many springs you got fitted?
Does your mechanic know we have a thread on here about doing work that is substandard or ineffective!
We can email him a service manual??
Adding extra springs amkes the take up of the clutch very sharp and the cable pretty tough to pull.
I could imagine that with fewer springs it would work, but would be vague and I expect it would slip like crazy
Smoky
to be honest with you mate, im not sureI reckon it has been installed incorrectly. How many springs you got fitted?
lol, he will now....Does your mechanic know we have a thread on here about doing work that is substandard or ineffective!
im gonna take my haynes with me next time im there, but would you reccomend the service manual over the haynes?We can email him a service manual??
the clucth take up is very sharp indeed. but the cable isnt noticeably tougher to pull in- its just feels as if the tension from the springs comes in all at once... whereas there was medium tension on the lever before the rebulit clutch (10mm freeplay then tension all the way to the bar) now it seems all lumped together...Adding extra springs amkes the take up of the clutch very sharp and the cable pretty tough to pull.
theres no slipping now- have tested that throughly... i just wonder what the hell is going on with all the freeplay on the lever.
and i miss being able to pull off in first without sounding like i cant use a clutch
sorry if my explanations are shite- just having a hard time trying to articulate all this lol.
thanks everyone for the help and advice, it is truly appreciated.
Why not fit a new clutch?
SOuds like something not right in the installation - loose main nut? Did you use a new one?
ref service manual - it is the lngua franca of garages..and IMO better than the haynes book of Lies
