Petrol leak
TROUBLED OTTER
Bike owned: DUCATI STREETFIGHTER,NC35,250R
Petrol leak
Post by TROUBLED OTTER »
Hi Guys,I hope you can help me with this one.I am trying to get my rvf400 to run without a petrol tank so I can tune it.The problem I have is, I,ve put a funnel on the petrol feed pipe and when I try to fill it with petrol it just runs straight back out of two small pipes inbetween the carbs.Do I have to create a vacuum or are the floats stuck open in the carbs. :pray:
porndoguk
Re: Petrol leak
Post by porndoguk »
when i run min without a take i use a homemade feeder bottle made from a litre catrol oil bottle, and a fuel filter, it then runs into the t piece to feed both sets of carbs,
i dont know where exactly where you say the leak is from but thats not right.
Re: Petrol leak
Post by Neosophist »
They are the over-flow pipes.
Your floats sound stuck indeed.
Put a bit of petrol in them (not enough to make it over-flow) and tap the sides of the float bowls with a screwdriver handle.
this might unstick them.
If not you'll need a strip and clean. (probably a good idea anyway if your tuning it)
TROUBLED OTTER
Re: Petrol leak
Neosophist wrote:They are the over-flow pipes.
Thanks guys,The bike has been standing round for a long time due to rebuilding her.I think I will clean the carbs to be 100%.Do you know the best place to get a carb kit from?Is it main dealer?
Re: Petrol leak
The only thing you would normally replace when overhauling the carbs is the float bowl gaskets, unless of course something else is damaged.
Rick-O on here sells float-bowl gaskets cheaper than anywhere else.
TROUBLED OTTER
Re: Petrol leak
Neosophist wrote:The only thing you would normally replace when overhauling the carbs is the float bowl gaskets, unless of course something else is damaged.
Thanks again for help guys.Ive E mailed rick o for the parts. :grin:
