NC24 and NC30 engines. What differences?
- mavisravis
- Bike owned: NC30 Race Bike
I have a a spare engine that I got with an NC30 recently, Originally I thought it was a 30 engine but noticed it had oil cooler take offs on the front above the sump. I think it may be an NC24 engine. How do I check, and what are the differences? I'm fairly sure it's been in a 30 as the guy I bought the bike from said he ran with that engine until the head cracked.
Re: NC24 and NC30 engines. What differences?
if it ran with the 30 igntion box then its probably a uk 30 engine.
would need the nc24 ignition box, coils and most of the loom for it to work otherwise.
what colour is the engine?
- mavisravis
That's what I thought it was originally. I have an ignition box that doesn't work on my 30, and is much bigger than the 30 one, I also have a set of coils that look bigger than 30 ones too.Neosophist wrote:if it ran with the 30 igntion box then its probably a uk 30 engine.
The engine is dark grey.
Thing is the number begins with NC13 but the rest of the numbers don't tally up with NC30 numbers.
did NC24's use the NC13 numbers?
- Bike owned: VFR400R NC24, GPZ600R
I'm gonna be a pain... If it does turn out to be an nc24 motor do you have the clutch rod for it and would you sell the rod?
Cheers,
Adam.
Cheers,
Adam.
PUll a plug out and see whether it is an ER9EH - the 24s use bigger plugs...
I've seen an NC30 engine that had larger plug holes (probably cheaper plugs :D)CMSMJ1 wrote:PUll a plug out and see whether it is an ER9EH - the 24s use bigger plugs...
If its dark grey it sounds like a 30 engine.. but different ingition box and coils? Maybe there off something else totally?.. The NC24 engine uses 4 coils. And its ignition box is a black OKI unit with 2 plugs
All the VFR400 series bikes use the NC13E engine as there all the same engine'ish.
Whats the engine number.. i'll tell you if its a 24 engine.
Also pics would really help.
