NC21 still not running right
Viffer77
- Bike owned: VFR400 nc21
Re: NC21 still not running right
I did test the diaphragm valve on the tank, it work fine. I don't know if that would answer your question?!?
It filled a 2 litre container in seconds (and some of my garage floor).
If the only problem was a hot exhaust, I would probably dismiss it, but as there is the flat spotting problem it makes me think there is more to it!
Buggered if I know!
Buggered if I know!
It only happens if your at full throttle for a while then?Viffer77 wrote:I did test the diaphragm valve on the tank, it work fine. I don't know if that would answer your question?!?
Buggered if I know!
Does the temp gauge go up or down when running at full throttle?
Viffer77
Temp gauge doesn't really move that much to be honest!
Ben.
Ben.
