3TJ Front Wheel Bearings
beasthonda
Bike owned: FZR 400 RR
Post by beasthonda »
Can anyone please confirm the front wheel bearing size for a front wheel on a 3TJ
I have not removed the bearings yet
I have some bearings I was given by the person I bought the bike from but have found that a one for the back wheel to be wrong
I have a bearing that I think will fit the front.
I/D is 16.90
O/D is 40.00 and 11.90 thick
and are they the same both sides
Hope you can help
Re: 3TJ Front Wheel Bearings
Post by Evilchicken0 »
There should be a code on the bearings
beasthonda
Both bearings say 6203 and the one I have says the same so I think I have my answer
How do you get them out??
Big hammer and a drift is the prefferred method
Take the speedo drive and everything out placing it on the spindle so you know the order it came off in.
Lever the dust seals out with a screwdriver put them on the spindle but you'll discard them later.
Put the drift in and knock the inner tube between the bearings sideways so you can get the drift onto the bearing then work around the bearing. When one sides out you can take the tube out which makes the other side easier. When you drift the new ones in put them in the freezer for a while. Cover the first with a piece of wood and drift it evenly, hitting at 12, 6, 3 and 9 o'clock until it locates on the lip. Put enough but not to much high melting temp grease in the bearing.
REMEMBER TO PUT THE TUBE IN.
Then repeat for the other side finish by locating the tube properly.
You need new dust seals.
plodder
Post by plodder »
Evilchicken0 wrote:You need new dust seals.
No you don't. If they're not damaged then there's nowt wrong with re-using them.
hunter
Post by hunter »
before you hit these bearings out,flick the dust out with a flat blade screwdriver,
heat the wheel around the bearing area with a hot air gun,don't burn the paint,when
you feel it's hot enough put a drift in and tap the bearing at the same time moving the bar in a circular motion the bearing will fall out with ease,no replacing the bearings
again heat the wheel,cold bearings they will drop in.replace dust seals job done.
Motorcycle Solutions
Bike owned: Kawasaki ZX9R E1
Post by Motorcycle Solutions »
Just go out & buy the tools much quicker, I fit em within 5mins...
The bearing drivers are a good bit of kit burt pricey and saves your paint work...
:Bmods:
jwer23
Post by jwer23 »
hi can anyone confirm what sizes the front wheel bearings should be for a 3tj please? and dust seals? need to replace mine but theyve fallen to bits so no code! cheers
Wemoto will probably stock them
