Oil Question
pf85
- Bike owned: VFR400 NC24
Oil Question
Im going to give my bike a service next week when the filters arrive- it is very low on oil would it be ok to top it up with 10-40 semi synthetic car oil? Or is this not recommended?
Re: Oil Question
no dont do it, car oil is designed for car ENGINES, where as bike oil lubricates, engine, gearbox, and clutch.
Re: Oil Question
rickyb_dj wrote:no dont do it, car oil is designed for car ENGINES, where as bike oil lubricates, engine, gearbox, and clutch.
get some bike oil - it is cheap enough.
car oil is a bd bad idea
Re: Oil Question
The synthetic elements in car oil are of a shorter chain than those in motorcycle oil.
Car oil is not designed to be chewed up through a gearbox, by putting it in a motorcycle it breaks down much more quickly and will loose its viscosity rather quickly..
Bad idea.
Just get some Silkolene 10/40.. it's only around £18 for 4 litres.
Bad idea.
- spooky
- Bike owned: nc24
Re: Oil Question
When topping up oil do I have the bike on the side stand or hold it straight up, ie vertical? Can't remember which....
pf85
Re: Oil Question
Cheers for the replies! Yes i'll just buy a 4litre jar of Silkolene 10/40 and top it up for now to use over the weekend.. it will all have to come out again for the service in a week
Re: Oil Question
Hold it level.spooky wrote:When topping up oil do I have the bike on the side stand or hold it straight up, ie vertical? Can't remember which....
Allow 30 seconds for the oil to level out..
Don't screw the dipstick in, remove it, wipe it and let it rest on the hole
kevin wilson
Re: Oil Question
i think it would be ok to top the bike up with a bit of car oil if you needed to to get you along to your next service ,its still oil like at the end of the day ,in the past i used to run my old nc30 and other bikes on cage oil the whole time and never had any trouble from using it either before i heard of bike specific oil lol
- vfrman
- Bike owned: NC30, 1098s
Re: Oil Question
kevin wilson wrote:i think it would be ok to top the bike up with a bit of car oil if you needed to to get you along to your next service ,its still oil like at the end of the day ,in the past i used to run my old nc30 and other bikes on cage oil the whole time and never had any trouble from using it either before i heard of bike specific oil lol
Don't do it! The additive packages in car oil can mess up your clutch. Don't ask me how I know.
kevin wilson
Re: Oil Question
the older bikes like the older oil from my experience,,,
,,,theres no harm to the bike in topping up the oil level with cage oil till the next service
