indicator problem on nc24
wayne84
hi the indicators on my nc24 have stoped working on the left side of the bike . tryed changeing the bulb but still not working .just wondering if any one could help me out with some info many thanks
Re: indicator problem on nc24
probally a knackered relay, fuse, or switch at the Left handle bar, (nc30 location) = check your conections down on posibly the lhs of engine make sure the 2 connectors are conected,wayne84 wrote:hi the indicators on my nc24 have stoped working on the left side of the bike . tryed changeing the bulb but still not working .just wondering if any one could help me out with some info many thanks
check the volatage at the relay when on and bulb holders, listen to hear if it clicks etc, its going to be something simple i assure you just fault finding really.
also check the fuses?
wayne84
hi i cheked the fuse . had a little play about with them and they came on then wen i turned them off they wud not turn back on . So guna take switch off and check it and check the wires. Thank u very much 4 ur replay glad u cud help me
Switch could be knackered.
try blasting it with WD-40 (stick the staw attachment into the hole and give it some)
wayne84
its not clicking wen u swith it over the right hand side makes a clicking noise. cud defo be the switch that has gone
