NC30 Rebuild
matt_nc30
- Thieving Pikey Twat
- Bike owned: NC30, 2000 R1
Re: NC30 Rebuild
They are from a 999, the 4 pad type.
Awsome stopping power.
matt_nc30
Re: NC30 Rebuild
Sun was shining today, so got up early and stripped it down some more.
Took it out front so i would have enough room.
Took the fairings off, air box, and clocks
I noticed the front rocker cover was wet/oily. In need of a new gasket i think.
The bottom radiator is shagged as well
matt_nc30
Re: NC30 Rebuild
The top seems ok though, just needs a tidy up/respray
Radiators off
Then it was time to take the carbs off
Easy
And finally it was time to loose the loom (im fucked when it comes to putting it back
As she stands now
Engine out is next on the list
Re: NC30 Rebuild
Great work... I am going to get radical on my no9 moto this winter. The old sod deserves a clean!!
- matt_vfr
- Bike owned: '89 NC30
Re: NC30 Rebuild
Pretty sure that bottom radiator is fine... especially when you see the price of a decent replacement
Mine looked like that as im sure most do eventually, but its just a build up of mud and crap from the front tyre, take it off and soak it for ages in some soapy water to loosen the crud, then blast it from the back with a hose/ pressure washer (go easy though) to try to shift it... rinse and repeat til its spangly! Then carefully move any bent fins back into place and spray it up!
Good work on the rebuild though... really need to do mine
matt_nc30
Re: NC30 Rebuild
Cheers for the advice matt, i will give that a go before i splash out on a replacement
Got the engine out 2day
Johnny Wishbone
- Bike owned: VFR400 NC30
Re: NC30 Rebuild
Nice work so far Matt.
I started stripping mine last September and I haven't got as far as you yet!
Re: NC30 Rebuild
Good work!
Where does that lead go to that's coming off the front r/h intake manifold? Pretty sure there is just a screw there as standard (for vacuum balancing carbs)?
matt_nc30
Re: NC30 Rebuild
That pipe is for the scottoiler, it uses the vacum to feed the oil.
Matt
Matt
Dynamohum
Re: NC30 Rebuild
as matt says theres life in that rad yet soak it over several days you will be amazed at the crud that gets in there bottom rad mainly road filth from front wheel top rad insects and crud i did mine over the winter used an old bank card cut into a strip the right size and used it as a pojer from the back of rad to clear the fins takes ages to do but well worth the effort finish off with a coat of barbecue or vht paint and you will reap the rewards of a cooler running bike when done. the missus watched me doing this with a look of disbelief over several nights whilst she watched tv if she had gone out might have been tempted to put it in the dishwasher first lol..matt_vfr wrote:Pretty sure that bottom radiator is fine... especially when you see the price of a decent replacementMine looked like that as im sure most do eventually, but its just a build up of mud and crap from the front tyre, take it off and soak it for ages in some soapy water to loosen the crud, then blast it from the back with a hose/ pressure washer (go easy though) to try to shift it... rinse and repeat til its spangly! Then carefully move any bent fins back into place and spray it up!
nice work sir keep it going
