Had a request to post up a few pictures of the '24 as I strip and rebuild her.
SO - first a little but of history. This is a registered '87 lady but has what is referenced as the 1990 colour set on the RSMotorbike paint site. She came to me in pretty good nick in 2004 and has had a good life since then. The only modification to the original spec was the addition of a linkpipe which exited on the rear left of the bike rather than the right. This pipe had a fixed can on the end which eventually fell apart and wasn't in any sort of condition that made it worth repairing.
I subsequently picked up a Coerce "Racing project" exhaust on ebay - very unusual piece, never seen anything like it. No baffles at all, no packing, the "Can" itself is actually a vented jacket surrounding the inner pipe. The inner pipe in turn has vents which line up with the airflow through the jacket - the whole system looks like it's designed to, in the least, improve scavenging - at best it could potentially generate negative pressure in the pipe, effectively sucking the exhaust gases out! Genius idea but I've yet to evaluate how well it works, and the sound out of it is harsh as all hell.
In any case, apart from that, the bike is entirely stock - and that's the way it's staying - end plan is to replace the Coerce with an original unit minus some of the packing so that it doesn't sound like a whiney sewing machine.
Done so far are:
- Plastics & tank removed
- Clocks & front subframe removed
- Front brake system removed
- Forks & triples removed
- Airbox removed
- Carbs out, stripped & cleaned
- Cooling system drained
- Radiator removed
- Rocker coveres removed & cleaned
- Valve clearances checked (one exhaust valve on cyl3 was out a smidge - elseways ok)
Right - so here's where we stood this morning:
Got the Subframe off
Got the Swingarm off
Have the engine almost entirely cleaned in place thanks to my super high tech cleaning kit which consists of a "Muk off" bicycle gear brush, a toothbrush, and copius amounts of Aldi's finest W5 Engine Cleaning solution (seriously.. silly amounts of it).
Tomorrow sees the swingarm get a makeover.
So far, the needs doing list consists of:
- Front caliper recondition (rear caliper is perfect surprisingly enough)
- Forks need an overhaul
- Rear shock overhaul
- Various bits need cleaning & painting (subframes, sidestand, etc...)
- Plastics, tank & wheels need to go for touch up
Will update again as I have news.
