Fork Upgrade????
Adicolor
- Bike owned: CB400 SuperFour Version S
Fork Upgrade????
Anyone here upgraded there fork's or even changed then to a set of USD forks????
If so, which forks did you use, hints and tips?????
Or is there an upgrade kit available for the SF, spring's, oil, seal's etc??? I see plenty on the forum for the VFR's and RVF's but not the SF's !!!
Thanks !
Thanks !
houdini
Re: Fork Upgrade????
i have see a superfour with a zxr400 usd front endAdicolor wrote:Anyone here upgraded there fork's or even changed then to a set of USD forks????
Thanks !
so that may be worth looking into
- royster81
i have stock nc30 springs outta one of my forks if you wanna look at using them in your SF.
karltheboy
hagon and hyperpro both do upgraded fork springs for the sf just call them they start from about £70 and then i would put in slightly heavier fork oil to as we weigh more than the japs
