NC30 - rear brake line routing
niffter
Bike owned: NC30, Yamaha TY 175
Post by niffter »
Hi,
Is there a "how to" guide for routing the rear brake line through the swingarm on an NC30?
I've has a search but not found anything.
Thanks.
mick.mh2racing
Re: NC30 - rear brake line routing
Post by mick.mh2racing »
Piece of cake.
Drill a hole throught the front of the swing arm on the top surface, sufficient in size to accomodate the line. Thread the brake line through a rubber grommet like the ones used in electrcal boxes, and then through the hole.
Having previously removed the hub from the swing arm, pass the brake line through another hole drilled about 50mm infront of the hub.
Alternatively drill a hole at the bottom of the swingarm and pass the line through that. Again use a grommet to prevent the line chaffing.
Where you position your holes depends on the fittings you use on the end of your lines. If you drill at the bottom, you'll need a 90 degree fitting.
Got some photos somewhere, I'll have a look and post em up.
A modification worth doing.
How hard can it be?
porndoguk
Post by porndoguk »
i to would like to run my rear hose through the swing arm, ive just ordered a set of goodridge hoses, which will be pre made so can i only do the top hole version?
porndoguk
Post by porndoguk »
just found this but wouldnt be 100% happy with spring catching it and the chain!
i dont think the cable tie is adequate!
http://www.akhara.com/nc30/nc30rearbrakeline/index.html
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
mick.mh2racing wrote:Drill a hole throught the front of the swing arm on the top surface, sufficient in size to accomodate the line.
You only need to drill one hole at the hub end as per the Akhara pics - the line can pass through the open space near the shock. There's plenty of clearance, never had a problem in 5 years on road or track with a cable tie holding the line.
'Take it to the Back'
mick.mh2racing
Knew i had a photo somewhere.
How hard can it be?
porndoguk
Post by porndoguk »
mick.mh2racing wrote:Image
are those 20mm grommets if so i have millions, (im an electrician)
if any one needs any ill happily send some out free just pay for 1st class stamps
Burbage
Post by Burbage »
Not (technically) the best of ideas to drill holes in the swingarm, particularly the one nearest the suspension unit.
mick.mh2racing
Yes they're the same grommets used by electricians.
I don't really see an 8mm hole weakening a swing arm that much.
How hard can it be?
Spike16
Post by Spike16 »
I dont think drilling some small holes in the swing arm has an majour effect on them, iv done it to both my road and race bikes and noticed nothing and alot of vfr/rvf racers ahve the top surface of their swingarms milled down a few mm to reduce weight and they and setting lap records...
