NC24 camshaft installation.
Re: NC24 camshaft installation.
Post by Neosophist »
Rear Left / Front left.. that sounds right.
I'll have to double check when I get home:)
Old Painless
Post by Old Painless »
No need to put yourself out matey, all sorted now.
Now it wont start, must be flooded and the battery is dead too. lol
Roll on sale day. :roll:
Old Painless wrote:No need to put yourself out matey, all sorted now.
Aha.. I did say that they are a bit of a money pit :)
Once there up and running though it's not so bad.
When the carbs have been drained they are a RIGHT PAIN IN THE ARSE to get running again :/
I have some jump leads and attatch my car battery to the bike.
Tank on, Choke on full
NO THROTTLE AT ALL
5 second blast
wait 30 seconds
5 second blast
wait 30 seconds
5 second blast
wait 30 seconds.
since its a vaccumn tap it does take a while to get the fuel thru... if your not using any throttle ist should be ok.
If you think it's flooded best thing to do is NO CHOKE, FULL THROTTLE, CRANK IT FOR 10 seconds.
This will pull lots of air through the bike and help dry the plugs.
Leave it 5 mins and go back to the full choke as above.
Then sell it and get a ZXR400 instead ;)
Old Painless
Yes, it is an IMMENSE pain in the arse. The only good thing about it so far is that you don't need to pull off the carbs to do the valve clearances. Other than that..... the good stuff is on a pretty short list. :|
I'll give it a start later on today. Should be running sweet as a nut now tbh, all problems sorted apart from a headlight bulb. :grin:
ZXR400 ? My next bike is a TL thou or an R1. Fuck this 400 lark. :ban: :lol:
http://www.youtube.com/watch?v=u9gSNq1J16k
^^ Much quicker than some of the 'big' bikes on the track :peace:
TL lovely though :)
Old Painless
TBF he was taking some proper liberties with some of those corners, im surprised nobody went round the outside of him at times, good riding though.
Ill see your ZXR400 and raise you a TZ250 :plus:
http://www.youtube.com/watch?v=_U-H0_xIyg0
Old Painless wrote:TBF he was taking some proper liberties with some of those corners, im surprised nobody went round the outside of him at times, good riding though.
Yep.. it was just a free practive on an intermediate track day.. no real hardcore nailing the berries off it :)
I'll see your TZ250 and call you on a
http://www.youtube.com/watch?v=dLUStolM6r8
Bonus points for Hi-Def and multiple camera angles?
Old Painless
Very good riding. The bit at 2 minutes !!!!! omfg. :shock:
4 angles at once ? lol
http://www.youtube.com/watch?v=rlAxnVS-aNA
Seriously needs to learn to get his shoulder off the bike though. Will come a cropper riding like that.
EvanTate
Bike owned: VFR400 NC21
Post by EvanTate »
Neosophist wrote:
Old Painless wrote:According to the VFR750F manual, you set #1 to TDC, install the rear head camshafts with the lines on the cam ends lined up with the lines on the cam guides then spin the engine 450 degrees and do the same with the front heads.
WTF does 450 degrees come from ? The uneven firing order on these engines wrecks my head. :roll:
270 degrees + 180 degrees :)
Look at the picture Mark posted at the top of the thread.. on the right-hand column it has the NC24 column.
It shows you what cylinders are firing at what degrees. :)
If your still having trouble I could take you some pictures of the cam positions relative to crank position :)
Would this still be possible? We keep getting a backfire rather than a running motor... :stupid:
:whistle:
Its already been posted with pictures.
viewtopic.php?f=24&t=1943&start=130
bottom of this page
