ZXR forks in a NC30
tayto94
ZXR forks in a NC30
Hi,
has anyone done the front fork conversion with zxr forks???if so what was needed to do it. Seen a set of forks on ebay but yokes and the centre pivot rod and all have to be changed!?
Also, anyone ever put cbr forks in an nc30? rr5 or rr6?
theoutsider
Re: ZXR forks in a NC30
Well I`m doing the conversion now,you need:mudguard,forks,yokes,clipons,discs,wheel,calipers,spindle.
I bought sp1 calipers which are 62 mm centre to center,just have to space them up,I used nc30 Taper bearings of ebay,and I made a spacer to go under the top yoke which was made from a old yoke,and bang on.The only thing which I don`t know,how to fit the ignition,and how to lock the bastard.Good luck,remember there is no cheap conversion
If your not doing this for cosmetic (i.e. you prefer USD fork look) then your better off upgrading your standard forks.
if it's >89 model it'll have decent cartridge forks.
Speak to Rick-O as he does kits and upgrades for the std forks that will improve your suspension :D
