VFR800 swing arm on nc30
muay_thai_dan
Post by muay_thai_dan »
ok guys i couldnt find anything through the search so....
...has anyone ever tried putting a vfr800 swing arm onto and nc30 or 35??
thanks!
-Dan
Re: VFR800 swing arm on nc30
The question would be why bother?
muay_thai_dan
basically to get the vfr800 rear wheel onto the nc30.... since its wider.
im assuming the vfr800's swing arm is different than the nc30?
it might not have much functionality for performance, but i guess might just look nice with a wider wheel / tire.
thanks!
You can fit a 5 inch VFR wheel to the NC30 hub - why not do that?
a 160 is about as large a tyre you can fit with the chain clearance (and even then you might have to space out the sprockets)
muay_thai_dan
CMSMJ1 wrote:You can fit a 5 inch VFR wheel to the NC30 hub - why not do that?
wouldn't putting a complete vfr800 swing arm solve the problem of chain clearance?
the vfr800 wheel is 5.5 inch and 180 tire.... so thats what im after. for the nc30.
would this be possible?
thanks!
ozracer
Bike owned: NC30 Race Bike
Post by ozracer »
To get more chain clearance you would have to get/make an offset front sprocket. There would be a lot of engineering involved just to have the look and decreased performance of a wider rear tyre and in my opinion is a waste of time. Others have fitted the VFR750 rear wheel with a modified hub, this looks to be the best option.
Cammo
Post by Cammo »
muay_thai_dan wrote: the vfr800 wheel is 5.5 inch and 180 tire.... so thats what im after. for the nc30.
It might be easier to fit your nc30 bodywork to a vfr800! :grin:
royster81
Post by royster81 »
muay_thai_dan wrote:wouldn't putting a complete vfr800 swing arm solve the problem of chain clearance?
thanks!
the chain is still going to come off the motor at the same place so moving the swingarm around isn't going to fix it
