NC35 Running issues. Ram air.
Gave the Nc35 an outing round lydden today, there seems to be a hesitation when getting on the throttle, this only happens after backing off or braking for a corner. As you wind it back on mind corner its as if it starves of fuel for a second before taking off, pretty upsetting mid corner and going off line everywhere. doesnt seem to matter what rpm your doing theres always that hesitation.
Otherwise the motor runs fine pulls like a train with the 14/42 gearing
First time out on full wets which was interesting, as was the throttle getting stuck full on exiting the first corner on the out lap
then the constant fueling problems meant an early day, decided to sort it rather than ride around it and maybe bin it.
Any ideas peeps? engine spec is RLR stage 3 ram air'd
- royster81
Re: NC35 Running issues. Ram air.
your not running a filter are you tony ?
- abrmoto
TONY,
Had it with mine as well, fixed ut never got to bottom of it, clean jets out, fitt new plugs, fit new battery and check no water in bottom of tank, all have given same problem at times.
Aly
Aly
royster81 wrote:your not running a filter are you tony ?
Aly, i'll check all those, someone else suggested water in the tank so could be worth draining out.
