NC30 wont start
ibby4585
Bike owned: SP's
Re: NC30 wont start
Post by ibby4585 »
Shit mate, i work just up the road, if id have known i would have had ride up today and helped you. Im not brilliant at mechanics but ive got all 3 of mine going. i could pop up next weekend if your still struggling.
Kris
spooner
Re: NC30 wont start
Post by spooner »
ibby4585 wrote:Shit mate, i work just up the road, if id have known i would have had ride up today and helped you. Im not brilliant at mechanics but ive got all 3 of mine going. i could pop up next weekend if your still struggling.
Kris
cheers for the offer. i will see how i get on after changing the plugs and fuel tonorrow, where do u work?
skinnydog0_0
Bike owned: Penny Farthing
Re: NC30 wont start
Post by skinnydog0_0 »
What voltage do you get across the battery when you are trying to start it?
spooner
Re: NC30 wont start
Post by spooner »
skinnydog0_0 wrote:What voltage do you get across the battery when you are trying to start it?
dunno as i dont have a volt meter
ibby4585
Bike owned: SP's
Re: NC30 wont start
Post by ibby4585 »
Kris
i work just nr Aylesbury, let me know, get some pics up mate, so it a genuine uk modell??
Kris
spooner
Re: NC30 wont start
Post by spooner »
yeah its a uk bike, heres a couple of pics i will take some when its back in one peice and running
spooner
Re: NC30 wont start
Post by spooner »
still aint running :down: put some new feul in and that aint worked but i have ordered a set of plugs from ebay as i couldnt find them any where local and will see what happens after that
Re: NC30 wont start
the vacuum hose is on the most outwards of the little nipples.. the big one is fuel, the middle one is a drain and the outside one needs the hose on it...
check it out dude...
spooner
Re: NC30 wont start
Post by spooner »
CMSMJ1 wrote:the vacuum hose is on the most outwards of the little nipples.. the big one is fuel, the middle one is a drain and the outside one needs the hose on it...
the vacume hose is on the little nipple pointing downwards and was when i collected the bike and the one pointing to the front of the bike has nothing on it is this correct of not?
Re: NC30 wont start
I reckon that is wrong - the downwards pointing one is a drain and cannot be moved..
the other one can be forwards or down...as it can be moved.
Swap them over dude...and give it a whizz :rocks:
