just confirming location of hoses...
yayoboy
Post by yayoboy »
is the top one for the expansion tank overflow and the bottom one that comes of the bottom of the air box?
and what pipes connect to the overflow on the carbs?
thanks all :D
fastdruid
Regular Member
Re: just confirming location of hoses...
Post by fastdruid »
1) Looks like it but can't be 100% sure.
2) Nothing, the two pipes with clips on that are in that pic connect into the airbox though.
Druid
viper_biker
Post by viper_biker »
Yes, first one is the coolant overflow. The second one is either the tank breather hose, or the hose that connects to the side of the air-box. HTH
yayoboy
Post by yayoboy »
fastdruid wrote:1) Looks like it but can't be 100% sure.
Druid
sorry m8 not those ones, the two banded together coming from underneath the carbs at 90',
thanks for both your quick replies :D
viper_biker
The 2 pipes that point downwards with the rubber band is the float tubes but they don't connect into anything. The 2 pointing right go into the sub-air filter on the back of the air-box. The one from the rear head feeds back into the air-box as well.
fastdruid
Regular Member
Post by fastdruid »
Druid
Yep, they connect to nothing[1].
Druid
[1] Unless you have them HRC modified.
yayoboy
Post by yayoboy »
thanks all spot on help as usual :D
viper_biker
fastdruid wrote:Yep, they connect to nothing[1].
Druid
*COUGH*
*COUGH*
