NC30 Gear change
Urahara
Bike owned: VFR NC30
NC30 Gear change
Post by Urahara » Thu May 06, 2010 8:34 pm
If theres a certain knack to it pardon me!
But i have been have problem with the gearbox. Shifting 1 and 2 is fine. But shifting to 3 it sometimes gets stuck as with shifting to higher gears. Never any problems downshifting.
Any idea on some finetuning to make it work nicer?
Thanks guys
arsey30
Bike owned: ftr223 650 bros
Re: NC30 Gear change
Post by arsey30 » Thu May 06, 2010 9:41 pm
I have found the gear lever can be hard to move on upwards changes when cold.
I fitted a reverse lever from CG125 or VFR750, and this gives a better change, but with more travel, it eliminates the linkeage slop.
Dave
Cammo
Post by Cammo » Fri May 07, 2010 12:40 am
Urahara wrote: Any idea on some finetuning to make it work nicer?
Check that the gearshift is attached to the spline in the right position.
There's a round mark stamped into the gear shift lever and into the spline, make sure they are aligned.
