Gear position sensor. Possible ?
PARUS
Just get idea to fit gear position sensor. Maybe somebody use and maybe it possible to fit from other newest model.
Will appreciate any help.
http://cgi.ebay.com/ebaymotors/90-cbr10 ... 739wt_1166
zul_cbr
- Bike owned: 1990 CBR400RR-L NC29
Re: Gear position sensor. Possible ?
PARUS, that is 100% similar to our 29 sidestand wiring. please check at the back of your sidestandPARUS wrote:Just get idea to fit gear position sensor. Maybe somebody use and maybe it possible to fit from other newest model.
It connects to the clutch diode, sidestand indicator and ground. the reason it says gear position sensor is because it prevent the bike to be start in gear.
correct me if i'm wrong buddy.
maybe u mean for this ? http://www.youtube.com/watch?v=bCsoqclU ... re=related" onclick="window.open(this.href);return false;
PARUS
Yes, I saw this but all of them based on wheel speed sensor and looks like not so precise. It I run to quickly but on the 2 gear it can show me 3.. Correct me if I wrong.zul_cbr wrote:maybe u mean for this ? http://www.youtube.com/watch?v=bCsoqclU ... re=related" onclick="window.open(this.href);return false;
BTW Accumen do same sensor.
PARUS
Hi,
Stop me if I wrong. We can use GPS (gear position sensor) from GSXR or maybe similar
And join it this the GEAR SHIFT CAM. Looks like it should be similar. Anu ideas ?
- Variablevalves suck
Hi Parus,
The idea is correct as the gsxr sensor gives a different resistance for each gear but its designed to be mounted at the other end of the selector and is connected to ground by a small pin/spring arrangment thats very different to the claw in the picture. The sensor fits outside the casing and the selector drum is smooth except for the pin.
Pm me your email and i will send you a parts list so you can see the parts.
Chris.
Chris.
PARUS
Did you get my email ?Variablevalves suck wrote:Hi Parus,
Chris.
