need help fitting alarm to my nc30!!
mavrick_001
Re: need help fitting alarm to my nc30!!
Hey Cliff,
I install intruder alarms which is a bit different lol I have a go at most things electrical when I'm in the mood for it, would be helpful to know what alarm you've bought, I'm guessing the fob will activate a relay on the control box which will basically short 2 wires together which will need connecting into the ignition cct...... only way I could see it working but then why remote start the bike when key needs to be in it to ride it???? Or am I missing something lol
If your a little unsure with wiring get someone that knows a bit about it to do it. A poorly fitted alarm is as usefull as a chocolate teapot.
vfr-nc30-2010
- Bike owned: vfr nc30
hey thanks guys for the reply
the alarm i got is called cyclone
i got a wireing diagrame but can only figure out a bit of it lol
i was able to wire one up to my old bike but was much easyer and diffrent as it was a moped!
can you post a pic of the diagram?
Old Painless
You need to join the ignition button wire on the handlebar (switched side) to the alarm box wiring at a guess.
vfr-nc30-2010
ok yh sure ill try puy diagram up
not sure actually how to put pic up lol
- superlite
- Bike owned: TLS, LB80 x 2
Have a look here:vfr-nc30-2010 wrote:not sure actually how to put pic up lol
viewtopic.php?f=6&t=7902" onclick="window.open(this.href);return false;
'Take it to the Back'
Old Painless
Grab a photobucket account. Use the IMG code it gives you. Like this:
[IM_G]http://i696.photobucket.com/albums/vv32 ... 162901.jpg[/IMG]
Obviously the first IMG tag is broken with a _ so it displays as text.
vfr-nc30-2010
try this http://i870.photobucket.com/albums/ab26 ... 396165.jpg" onclick="window.open(this.href);return false;
Funny looking wiring diagram tho
