NC29N 520 sprocket, which bikes cross reference?
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Re: NC29N 520 sprocket, which bikes cross reference?
Post by zul_cbr »
cajun wrote:Well it turns out that the front is a JTF565 in a 520 pitch. Which is a Kawi 650R front. I also found out that the 900RR will fit but the holes that the studs go through are a little too big. Buuuuuuuuttttt.............. the 99-02 R6 sprockets fit perfectly.
hi cajun!
nice information...
so, if we want to do a 520 conversion, we can use 650R front sprocket, with 900RR or 99-02 R6 rear sprocket... :smile:
as the 900RR bolts is slightly bigger, can we still use with straight swap or any adjustment needed ?
cajun
Bike owned: MC22, NC29,NC35, 2 FZR400's
Post by cajun »
Yep, 650R stock but you may have to space it on the engine side, I'll let ya know tomorrow exactly how much, and for the rear either a F4,F4i, or a 900RR rear sprocket will fit in a 520 conversion but it may be advisable to put some washers on the outside of the sprocket, as the 400 holes are 10.5mm and the 900RR are 12.5mm.
zul_cbr
Post by zul_cbr »
cajun wrote:Yep, 650R stock but you may have to space it on the engine side, I'll let ya know tomorrow exactly how much, and for the rear either a F4,F4i, or a 900RR rear sprocket will fit in a 520 conversion but it may be advisable to put some washers on the outside of the sprocket, as the 400 holes are 10.5mm and the 900RR are 12.5mm.
i appreciate all the informations cajun. waiting for your update...and thanks :)
