Who is using Mychron ?
At the monent planning to fit this next season. Is it difficult to fit ? Which sort of function it able to handle on NC29?
One more question - do I need expansion box?
I really planning to make injection to my babyblade - will I able to use it with cbr600rr wiring loom? Or any other maybe ?
Re: Who is using Mychron ?
Paurus, I run Mychron 4s on my race bikes. Simple to install and the Mychron 4 doesnt need the expansion box. I have revs, temp and lap timer plugged directly into the dash. 2 * 9v battery lasts the whole season. simple . The on in the pic you have posted is a Mychron 3 plus and this needs an expansion box which is a pain. col
What about in comparisson with Translogic? I saw translogic and saw some video where it was fitted to RVF.yeurman wrote:Paurus, I run Mychron 4s on my race bikes. Simple to install and the Mychron 4 doesnt need the expansion box. I have revs, temp and lap timer plugged directly into the dash. 2 * 9v battery lasts the whole season. simple . The on in the pic you have posted is a Mychron 3 plus and this needs an expansion box which is a pain. col
dont know mate, never tried the translogic...
Ok thank you mate.yeurman wrote:dont know mate, never tried the translogic...
I'm still thinking to fit Mychron 3 due to bigger display against Mychron 4s. At least it looks like from the picture below.
But Mychron 4 allow to fit Lambda sensor or maybe some other features. Neither the fact that I was a big fan of this, but it will be better to have some option for future tunning.
Here is some photo stolen from you site. Both Mychron 3 and 4 looks good.
And I see you fit you E-box at the front. Why you didn't mount it on the subframe?
Which socket your E-Box have got ? Because I generally saw with 4 docket, but yours have 6.
Just write wiring loom for Mychron tacho panel. Only question - can I use stock coolant temperature sensor and connected it directly to mychron. Any ideas?
I like to keep oil, headbean and etc light - just fabricate box for them and fit it near mychron.
As far as it will be road bike - going to add 12V external power supply....
Parus, you should be able to it's just a standard thermistor.PARUS wrote:Only question - can I use stock coolant temperature sensor and connected it directly to mychron. Any ideas?
Yes, I think so.Cammo wrote:Parus, you should be able to it's just a standard thermistor.PARUS wrote:Only question - can I use stock coolant temperature sensor and connected it directly to mychron. Any ideas?
I dont think the stock coolant temperature sensor will work, you need these for the Mychron 3 and 4 units:
M10 water sensor plus the joining adaptor to connect to the back of the Mychron unit
http://www.kkckartshop.co.uk/pc/YELLOW- ... 5p1943.htm
or this type (newer version)
http://www.kkckartshop.co.uk/pc/WATER-T ... 5p1667.htm
Col
Col
