help with the cluch cable
goughy87
- Bike owned: honda nc30
hi all my cluch cable has no tenchon at all and it is stuck on how can i fix this plz help
MexicanGringo
- Bike owned: '30
Re: help with the cluch cable
Thats no tension? By stuck on i assume you mean the clutch lever has no effect? Check the cables not snapped, if not adjust the nut holding the cable outer shield to give the cable more tension, this is on the left side of the crank case if looking forward on the bike, it really obvious you cant miss it
