Question about Forks
Christoph
Post by Christoph »
The garage has said the fork seals on my NC24 need to be replaced. I don't want to do this myself as I think it would just end in tears.
There is a guy a couple of miles away breaking an NC24 and has the forks remaining. He said they are in good condition and seals are are fine. I can have them for £15.
So, rather than spend £100+ to have my seals replaced, should I buy 2nd hand forks instead?
How should I check the condition of the forks? bearing in mind they will not be attached to the bike or a wheel.
Cheers!!
Cammo
Re: Question about Forks
Post by Cammo »
Fit new seals to your existing forks and buy the other forks for spares at that price...
Ask a nearby forum member for help, 100 quid is too much.
eamer1989
Post by eamer1989 »
damn thats expensive i think garage prices round here are about £50 for the job to be done
there easy to do just get a guide book hynes or w/e and do them, easy as pie
Christoph
Post by Christoph »
Easy if u know how ;) They actually quoted 125+additional cost to remove forks from bike.
Christoph wrote:Easy if u know how ;) They actually quoted 125+additional cost to remove forks from bike.
:pmsl:
Forks are easy - bite the bullet and learn it. Once done, you'll see why people are taking the piss about £100+ for fork seals!!
Buy some cheap seals and swap them out. Buy them other forks anyway for £15 -bargain.
NGneer
Post by NGneer »
CMSMJ1 wrote:Forks are easy - bite the bullet and learn it. Once done, you'll see why people are taking the piss about £100+ for fork seals!!
+1 - they are really not that bad to do. Not sure if the NC30 springs are the same but if they are, you could also get a set of those from Rick Oliver and upgrade your front suspension at the same time for less than the £100. Top upgrade too
