For the F3-TT nerds among us.
- CRM
Re: For the F3-TT nerds among us.
Is a frogs arse watertight ?G-MAN wrote: so , is this post going to make the sticky section?
Amen.
Superb post that G-Man.
- micpec
We want more! We want more!
Keep up the good work posted on here. I like this sticky
You really need to be able to read Japanese to understand this (but theres some cool pictures)
http://www.jacksons-lair.co.uk/VFR400R-NC24-Specs.zip" onclick="window.open(this.href);return false;
The NC24 sales cataloge explains how the VFR400 NC24 was adapted from the the 1980's RVF400 > New VFR400 on the first few pages.
Also has some nice pictures of the NC24 and the engine :)
G-MAN
Here is some more info for the F3 nerds
G-MAN
G-MAN
Yes I know its messy
Knowing the structure and function of the machine parts.
That's the first step 1.
\ Black box will not start 〃 Nomamaji and tuning.
There will be based machine
Bok some parts kit. But wait,
The car that Kimi would have understood how
User manual and, if you read the service manual
Tentatively will force the evening Ji Yeon and race cars
But it ran out Sir Bu emergency kit
Kitara Kimi point out that mud bugs 7
Incorporates only parts of it are
As a racing machine is state of 赤N坊
It, how you fit your
Then, becomes a problem to get better performance or crab
It's Setteingu
But an important part of the machine structure, operating principles and
And know that the basic
Gil is not in its application Setteingu
Soaked with oil and
"Black box" Let's fight
The harvest will surely they would have a great
Bok compact, high rpm and high output ^. Strength
Seo Engine 4
Bok Mesotsu 3: Webmaster's racer ^ Bu Tsu
Is
De-1,?13 and, based on commercial vehicles
Tsukuriage a racing machine with a speed that
Compete in one category, the quality of the base model, Resona
Bointo major feature of the engine is good
Be. Only slightly altered, high
Power - even if the engine that, whatever
Also quite high and the Ha. This one is out of Wa
Some of the potato.
Les, 1 Thing, required engine machine 'that is quadrature
Points to the many that is compact,
Friction / 』, Sai ^ ^ I can.
Two parallel 4-cylinder V-engine
Almost the same width only. This front
Can reduce the area to reduce air resistance,
Fastest-up is also beneficial. Way! ! De 乂
400 air resistance coefficient is roughly equivalent to II 3 25011
It. In addition, a parallel position of the engine mount 2
Scenery can be low-cylinder, low-weight 'Parasoft Lee 匕 same. Resona
On top of five greater bank angle can be 简呆
Jobs
1
Power head with a bottle crankshaft benefits foreigner
It's one. As a result, power results 搞 shaft Go
Ku so, power to force Shima Tawami be eaten Su
User may follow from a small, easily output, torque
Direction -! : 闵Ru the can.
It also narrow cylinder angle of 90 1. Setting
That, one can eliminate the following 报则 rose
And will contribute to the other of one small capacitor 处,
Because it takes less stress to the frame, S
跄先 some design features a frame advantage.
But a lock.
Crankshaft main bearings, the number of
Parallel 4-cylinder engine for 5-6 Isao Tokoro,
V 4 in 4 locations engine power. Friction output
It is also eaten by the Rafurikushonrosu Shima
Lee Su plane force can therefore be Ham. V 4 Engine
Is smooth from low revs up to high rotation of the S
But due to the low Rikushiyon greater.
Leisure @ foot intestinal gas
High C - and friction Rufutaimingu (^ 6 电咸 Education accepted the 丨 hurts
I Nshisute 1 卩 Kamugiatore Soviet "one of the first feedback from Huy.
ソド円に
New to the group of eight Imekanizumu
Benefits are inherent in the V4 engine
And Caro E, V de V 4 feet mounted on the engine
To two second-generation "also known as the Baie kimono, I De 以
Have adopted a new mechanism of U.
Kamugiatoren ginseng
This is a 'machine works 85 years from the Mado II
Dno one's feet Kku Gu. Ejection of the camshaft. !) Scheme
^ ^ By the gear from a chain of
A more precise valve timing at business 间転
Ru. 60 charged in early Se, Honda 110; LesSa
Kamugiatoren had been adopted, and this
Is the meaning of the cam chain cover reliability was
味でのギアWas a train.But --
Choi is one of the Ku ^ 問題Na reliability, and its lightness
Combined, the main chain cam 1311 ^ ".
Kamugiatoren chose to de-IIV is
And this is a different implication. High rotation and high output
LES aims to Thing 1, the engine is rotating at high
Dari cam chain sagging, the ability Bruno "Les
阅閉 timing of the probe, it will go out of the high rotation
售 become disabled. The 110 cam chain force, the force
, Who is privy to the 振Renai Muchen
- Friction by First Ntenshona
Would also interfere with high power. Kamugiatoren
By adopting the friction is
About 30 ^ is reduced, they ceased to be improved output
Ru.
Mugiatoren employing force: ^ a problem
Will the gearGu Kkurasshu BrunoLes Gu Bruno by Bruno
Butaimingu it's crazy 'is, this is Serashi
Sub-function called
Gear system adopted
That data by the Ministry of Su. This Sekandoa
Kamushafutogia Idorugia and used, 嚙
It fit the other gear, the phase shift slightly
IPSJ sandwiched Gatchiri main gear and the gear sub-Ta
Server in a way to stop Kkurasshu '. This I
A more accurate Bruno Rubutaimingu Gu 'power - to be.
End 眷PibottoajiYassExpression cart1 RoccaArm
1 Ttoajasutosukuryu the data pages, Fulcrum
By bringing the side of the fulcrum around Acid dyes
Reduce the moment of, reciprocating valve
Reduce the inertial mass, they contribute to the high rotation
Ru.
Straight Po cart 眷 1
Said narrow angle carburetor 52. Nearby, Pau
Sail de
Little change in cross-section of the cart
Rather, inertia and pulsation
Since taking advantage of dynamic effects,
Volumetric efficiency is greatly improved.
Other 180. Pont by adopting the crank
Reduction of gross-pin, light-gram of each part
And quantified, enabling high rpm and high output from
That.
Straight from the cart that was to be ^ lose
^ ^ Be sent to the flame without. !59881*0: Large towel ni ^IIAnd.
There is no magic kits and parts Patsuji
"The cam shaft. And I was out of power
They "" the exhaust sound even if only large ^
Power is much better, "said a voice as well
Ku questions. I even built one Kittopa But Tsu
Power is something that should not go up.
I do not think of an orchestra 敌 去 Bo
U. Ude you have a good individual members of the Force Su
As Ta, the one who put together the song
It would become inconsistent performance if
Wax. In addition, low-level orchestra,
Same as the one who had only good members
Thing. Ude other members of the Tsuiteike
If one Nare, low-les-level performance is as a whole,
Become something.
And it is also 丨司Ji tuning.
High enough state of the malware used to race 1 Bruno
The ability of the car-based, hypo further
Tensharu to withdraw is not easy.
Those obtained from accurate data and test Bu da through dense
Performance down could lead to the law must be reversed.
Tuning and that they 丨爾 this east
U. Means Chuningunipauappu
受Ketora but often, the balance of the body machine enterprises
Better things to do to take the SuA - young] goes.Resona
Results went with the balance of dimensions 办
One force?Ha. It's a Waatsupu '. Camshaft
^ ^ If you leave the tomb 丨贼 grandchildren even if normal
The balance of the original engine with Reversal
They just are. Inhalation of exhaust from the genesis and progress to trial
If you think the LE, the one muffler and carburetor
If the combination give a soul to be upright camshaft
Can not: ^ it should get a.
Tuning that is the same as the conductor of the orchestra will
After power up and turn the engine
The competitive power of the engine body so
丨. Thickener system should also consider tuning.
This is the entire machine to be deserted 'Jumper, Reims
If something 仕上Gare tight, it Chunin
Gu 'is) ^ which means that power.
It is first vertical and the principles 辭日 Osamu
It may take ~ 泌要 power. Word and power up
Even going in, there are many factors involving
I want to know that there are founded.
Each kit is part poppy ^:
Not come from, all Totaruba, Lance
It's made from the perspective that this increase
If you know Kimi's car will be fast and reliably.
Four-cycle engine
Single breasted three Chuninku Bok
Power of one engine, one of the following three effective I
You Know What it is drawn, Onozu
He will come and see the tuning point.
1. Volumetric efficiency
Engine, the explosion of air and mud Gazorin Aiki
Take the power to rotate the inflation pressure originated
Say it out tools.丨丨 及 they air to the engine
Is pounded into, 11 - the hen, that in the process of expansion,
Gasoline is needed only when the expansion. This
Mix a little gasoline on the air for 吸人
So it '.
If we just get a lot of power just gasoline
Ran toward the; ^ ^ ^ 丄 could rush for over-quota
Something has come into force when the door overtaken ball5! The closing;! )! And say.
Not as on the power of the engine
The Geru is heavy or inhale more air
Be required (for gasoline is ^! Mixed with air
ADD Eru if only depending on the ratio). 'Ho 乍気 large amount of
This is because the higher pressure when the U Lin.
That this rate 膽効. For example, 4-cylinder 400
1 1 ⑶ cylinder engine's 100 忧. Rain
Suton is slowly lowered until when,
He called one cylinder to the mixture of 100 Shim.
However, to enable interest 试符 州Shi suction pipe and exhaust,
And yet - the server in question may help someone closed valves
120 ⑶ be possible to put the mixture near future.
Lee is the main factor 權効2Improve the effectiveness of two Su
Ru. ① I X opens the first valve, the Bisuton!
丨入 cylinder by negative pressure suction wanted]
Mixture is sucked into and accelerated from 钎.混公
Guy is the inertia of its own, one cylinder 100 Shim
Momentum over into surplus 100 ⑶ (inertia). Mixed
If I feel "Oh, no, too much into" I thought (or
I do not know what) when I '~ Rain is Banrebu
So close to the Tally.拽 Ya got used to it and power fruit
呼ぶ。
The 戯非 trachea is a tube for the resonance (the exhaust pipe
If you think it easy flute) flame ^ ^ Su
吹Ki出Shita specific frequency of the pressure (by pressing the wave
Been received, and to consider also fade
I) and - to come. Pressure of the exhaust pipe;
Negative change in pressure. ! That is, 2 X Reb shutting the Roh Mu
Ru before IIX [When I started to open the valve (1 e
Burlap rather) server port, and Nollet
ブ pay threat5So that negative pressure, the length of the exhaust pipe
I'm going to set and, if Su negative pressure leak in the new I, mixed
@ Spinning top in the cylinder with great force to pull
Be. This) that the power Hall effect (note that this vein
Differential effect of suction pipe can be seen). Ekizo one set
Strike system that further increases this effect
ムだ。
Zhang B 财非 trachea, Banrebutaiminku, the - election to
By Lovely Idol - to improve efficiency. But - and
@ The 38 mixed force, "etc. The 燃舰 always calculated
II it does not in and of where they are and 隹.
Combustion efficiency and
More 取Ri入Retara mixture, then etc.
Think what U do produce energy.
Energy mix of 'high I said, want the pressure. The
For the - the percentage of air and gasoline
That ratio) mixture forms with easy-to 燃饿
I like the pressure of 'the, - a spark from the plug during the
Skip down to do it.
Teng can do to improve the ratio, the Gazu 纖
One way to get there from a high pressure,
- Sachi and effect - and because of the Chen system, - 匕
To pursue necessarily mean that there is only
Are not major. And also incur one-car cylinder
It is not. In the engine, piston,
Piston!; Friction by the friction link Gu,
Friction in the bearings, these kings to 燃鄉
Some of the force would be eaten (Furikusho
That Nrosu). Other air in crankcase
Power and pumping losses due to ejection of the valve sewing section! !
There is a loss of energy required.
Reduce the loss ^] ^ ^ way the power factor: You can make the
@ All but certain to be effective only in the number of rolling
Be effective in the region. Departments and especially Furiku
Shon is proportional to the square of speed two times higher
Effect of rotation frequency is known to be a big Oko
To get the high, - 1311 to 啼明 匕 state ignition with suitable 匕 8
心Ta D and power houses will '. Also, an important element of a three 燃細 also spark a strong dog.
It must be used in de-a 3 - room
Stomach is not big changes. Therefore, de-3
It should be focused on the machine, always ^!! The sparks that
Ignition system to be obtained, and Kyabureta
One is to make the settings.
Yo. Mechanical efficiency
Mixture - Ou Tsutomu is depress the piston.
Such strength connecting rods, crank through, --
Address! & I Sachi times from differential ^! !!) Change. Force is
Or rather the power to change and turn all the power,
嫩 not possible to be a job engine. To increase the power of this
That idea. 11139 is also slightly higher friction loss becomes significant.
De 誦册 0 ^ 7 ^ 00
Bruno recombination Retsu is just "not Waappu. Totarume "Think of Lance [
Head around
Four-cycle engine heart 部Ta
4 for Saikunoreenjin,HeadYamawa
Ri is - drum: It's part of Preparative required. IX, 2 X valve and lock
广 car, etc. Arm Germany | of ^ ^ us,.Tsu toAround de
Results of the engine and determine the case following the tune of congestion
I can go. Particular. The important thing is Banrebutai
Vea 甸 Efficiency with odd timing I: and the high rotation
Barubutaiminda but in the accuracy of the castle. 1
Racing, engine, Padres, Norebutaiminku, the
Increase the maximum amount of lift to take large, non-award Sir ^)
What is the rate of improvement has blende. Also, due to the exhaust pipe
驅城 "The more fruit mixture from valve IIV
吸人 for a new gadget and the mixture 燃观
Su IIV order to encourage the elimination of valves and 2X server
However, its vice; Kamushafu Fun And as things
Cart has a built-in ease. To
I want to note the IIV, 5 X cam
Bok to confuse the direction of the shaft,
Come meet the Bok mark Kamushafu
Jananoba Kegaki end of the shaft surface
Chitin and to mark it to fit.
One because it fit the gear 嚙 - Tsu
Even Barubutaimi: / the da, getting mad
It would.組Mi込Ndara 2
The translocation 以 Hikuranku 〒 - 丨 Yukkuri in "丨 try.
Bar, Lev Bruno,,: ^ and Bisuton, they Kotsun 与Tsu Toi
Art U 'is different if 黹 & Instructions.
ー cord is open to the valves
丨丨 拂 Ru] there. This
OhAnd Barappu呼ぶ。
Was higher than the power を い た シ Ritz 1
Timing "engines O
Is a large burlap
Taken. All these
Professional and camshaft
Hui determined by one Nollet
Be. FREE pop-key
Tto (Novice 'ju
For Nia) is the,
2XII!]InKamushafu also
The cart is available.
Bal 萵冋 pigs on abduction
Timing 'of. | | 沾 the one?] I
This can not mess around.
To this chart, Uto, 15 ^ 1 - 现点 before top dead after 镅 Barubuka We have started from the 5 'Mole is,' 糊Ji Rubuka
Oh is a worthy Ru / Rabbu become one. : 辦. Big and how heavy or Dian Ru ㈣ period.
Four most common problems Saikunoreenjin
Valves | "| Ri. Banrebujanpu 14 in grain products (Bar
5 XKick when the dimensions of the camshaft, rocker arm strength 稱 they had
The interest rate goes wrong, and hold the rocker arm stool spiked rubber tubeII
One of his valves 11 -: a force from the force of valve spring
Vea valve lift near Perugia in greater 般大
To pump ^! Elephant) and Barububaunsu (valve
Spring back when Kaka ^! 丨 away with Bibi Ke
Leap 5 images) by force5Many. Valve
I'll jump in under the |! ! There is no problem], Bruno "valves
^ 起Ko trouble with the spring
Su.Banrebuba, Bang Eun-Soo is a great shock toLES
Probe system. ^ Or employees, this is happening valve
And Ru, the piston 1 point, near the services because
Banrebu impossible to hit a ton.
Bu X, around valve parts kit is available
Tappet clearance is I 况, 2X ^ 0.13
瞧 it. If Measure V de Rokkaa 1140011
Su Q camshaft measurement system and slippers 1
Ru. Clearance less than the base model
The warm up is to care. Cold
Intensive and a number of valves at Ordination - The Chang
Side also incur to precede, Tapettokuria
Lance is gone, slip one arm Rocca
Under such problems would wear 1 而 Padres. Until
Ta 问Ri form a valve when the engine oil
Ku 蚝 be applied. The engine also incur 嫩 Hazime Shigeru
Until there is a time lag from around the Ile 轩 years.
Addition, rough surfaces in mixed Brush Co. Port Fuel
Bed-fellow, I'll make a smooth flow to archiving on port
If you also polish the four Saikunoreenjinchuningu
One of the port diameter, but the fruit is saying 愦隨 information
Since it has been textured, and conversely too polished Padres
Watch out because one would feel that he Wa ヽ 瘦. ^
Even pat the surface feels rough to 0 8: I.
To convey to the rotation of the combustion pressure
Ng Bok services, role of connecting rod
1 an engine tuning, the Bok points
燃瓶 赚匕 up the power that comes to mind first is
Pawaa the more powerful by
SITEMAP. However, the polished surface of the cylinder head
So to increase the ratio of the Kamugiatore
Until of the tappet clearance, said rocker arm narrow the needlenose pliers, Differential
And then to turn Ajiyasutosukuriyu Mika Kanai, easy to do,
Were not, the string of vehicles and one Su Bae II suit
13,500 to around 10 minutes in the rotation Reburimitto
回Seru it.
Bruno. Handrail of Reb ^) in Lee Hiroshi them; it shouldInSheet surface and length of the pocket too
Is too large to ensure that per. Also, the Konbaundo
BalWavesTaiji adhere to the system and valve guideHairCitation き す こ fromSo;; Ru.
Approximation! (! Ttara 赞, 丨 just in case: Check the working face. 册 Type (当Ta
Check the reset termsDoIf Stan )(?)"^) thin coating of the Casa, Su reset if valve
赚 嫩頁 to the dynamic combination and hit5Know. AlsoImposeOnlyだと当
Or plane! ^ Ji:!:Can Kku. AlsoPointing to the valve; ^I1711 only seven deer dogs
Another way to try to check the age of the 哮 Ili.
Bal Kriss per width of one cartInWas @ a (g 1 夂 Bal KrissLi
Jitter - system with --Shall fix the cart surface. Osamu Masashi; and D is more Professor Sir
So is the service manual, follow it.
Ng Bok fold when the service is, II 15 in the edge tone
Abnormal combustion can be easy and there Hitosupotto
Pottery can cause, Nshirudarainda pages
From partner and I use the bevel and lightly.
Abnormal 'is a strong Bisuton aluminum for 燃饿
Because they.
In airtight cylinder piston ring 1, LA
Ina surface lubrication, heat 1 (Bisuton - cylinder
Cylinder
Piston Ring
BisutonringuInWhat is the Marerufeisu. And 合I口180”戯棚 1 (75980
If we had all Taatari surface traction, so males should also 纖 ^.
- An icon? Not for that for fimbriae. Between gear
Distance from the axis is not changed. Then considered
Ru is the head heaped 励比 Bisuton
Yu promote 去 up but, - the form of higher 匕
While the letter, Bas, valves and the clearance of Bu ..
Given the need to take a minute.
Valve timing, especially the note changed Co.
Meaning should be. Junior. Novice
Chen piston system class, the base model pistol
And NgThe connecting rodUsing intact. Piston
Remain normal, light enough. DurabilityRegard
Even the city of Syariki Su Bae; ^! ^ Also intended to be run
I have no problem. I kit (8-level international
For) further! ^ Titanium and aluminum pistons
GongLockDE has been provided, piston, Rain
The Sutonringu ^ ^ Meyasu of about 1000 - it.
Bisto; "^ 8 ^ 5 @ 8, lightly edge! Ri can help someone, Hitosupotto!
Do to help5! ? ± ^ 14 can be accepted that even a little lower.
1) is an important component and has a job. Service
When you check the piston rings at the same time t
I'll also check state. Cylinder
Sliding surface (and 合I口 180. Su direction at) Taa fiasco
Tally and they have the ring! ^ 5 - they have
To ah cod. ^ ^ That is, a set of rings Su
^ ^ I have to Bae.
Bisuton, RCLockDe force in the Klang 拉 燃彬
Kushafuto telling! "』 Power converter to convert three 却変
Important parts that require it. Unduly light:! The of I
考えてコンLockBuff or scratch the cover for partial de -Etc.
Is not better. Remain sufficient Nomanore
It's light, only harden table 而 ^!; 现 (^ ^
现), so in it, cut the pattern of flame surface hardening
Shimatsu is to take significant 'falls 变 the intuition
Should pay attention to だ の で.
Also, when one-year-old Hall bar dyeing ^/The oblique 站剤
Using these, 'parts that require boats
Forces also carry out checks and cracks5, Li
Think である.
Clearance; to measure the clearance is a useful 則定 雅U Buresuchigeji
Place the bacteria that are constant Buresuchigeji place,? Give the torque.
^ You can still water on again off the clearance gauge to measure 爛 and crushed.
When parts form a kit,
Metal and big end Konrotsudo
Crankpin, Kurankusha
And softening metal and Jananore
Oinorekuriaransu take the
Let the bottom. 40 to 45 micro -
To fit the range of icon
They. Oh Metanore thickness of the three types
Ri, with the goal among them
Also closer to choose.
He enthuses, crank
Les nano-shaft and one of the chestnut Ja
Aransu is taken too large
And it. Because cluster
Nkushafuto occur between oil and journal).10:
In 问転 against the centrifugal force of the crank
Gong crankpinLockPeople DE - end - of the Ministry of Metanore
Because the oil has 叫. Conversely con
15 Chestnut let the big end rod and crank pin of Metanore
Aransu is not too much smaller.
Curiously obstruct the flow of oil, metal file by age
It reduces the surface heat 设. Clearance
Su is Puresuchigeji measurements, or Shirin
DaAGauge) that 丨]. Gong andLockド large scatter-shaped
Oy of ^ / clearance. 丨丨 丨? Screws to put in a box
Partnering with the seat attached to the surface and oil paint.
GongLockDegas & (?) Metal and KurankuhinAndSchilling clearance - in page; D Ru has been shown in Figure
Knowledge of! 丨 sleeve dissipating 161 "Ru. 扣 this; ^ 1 reactor cut-Shi, Napa 羁彰 摔 to shed the oil well has been magnetic
Power 轩 clearance! ^ |: 3! You should be the case. 'I,
Con. Large Tsudo 5 ^ | ^ ^ 0 创 one journal!)
Oil were conducted by the thigh.
Conrod
How a Bok Kurankushafu
Bok points to rotate smoothly or
GongLockFlame from de:) ^10:Li ni yo ru ^ 18 power to make
丨 丨卟 the ^!^!! to - the power of the5'Crankshaft
Role of it. What is required is the tale of precision parts
Them, and care must be taken when handling 丨分 it. Me
Want to avoid dropping to the floor or even twilight.
1 In1/‘Reset
One crankshaft counter weights and 躺寸InXiang or shaving or brushing
Shiku and ^; because under, and then the process should not blindly.
The crankshaft is - and Nde Wave, one Na Ja
Oh you get the metal parts and burned LE
00
Also, how smoothly the crankshaft
Times the power to the rainbow, but a great point. Sonota
In even in the preceding paragraph, the description is Oirukuriaransu
Okitai kitchen and take. The metal bearing
The engine used is backed Su axis 纖 Metanore
Ru - that is exactly the molecular level
I have a bad thin Oinore lubrication.
When taking a clearance, scratch the bearing portion,
ゴミ,が不]1They also check for any
Mun's very 贤 points. Il 而取 old hole
Ri 咅 intent mentioned in 15 minutes it felt overhang
If you like Ru, Gomui; 丨 yield 'Okou been removed.
Su and not to put oil in the hole when the force
Note し た い.
The crankshaft as described above) 落To the drain
That, but that is absurd and, smooth
丨 | monument to mention the balance of the Bok Kurankushafu
The hen has to care. Because of the engine
Okeru the rotation of the occurrence of stress, | b I come number two translocation
Proportional to it. The more commercial 问転,
Padres demanding, requiring a Reims. I kit
If you fancy a desk it is a piston, the connecting rod
Restoration of housing and so I 丨 Ku last 4 |! Of games? [Of the Ku 粍 丨丄
Wait one minute counter and the balance of Tta
For Ru, opposite the crank pin Kurankuu
圣 Guraida art of Ebu from one to the quotient of seven thigh
で削る。
Crank counterWayトは、Stove
TsuDE, and pistonRoh"Take a Reims, clock and
Some parts are determined by inertial mass ranks.
One counter weight! You of, subordinate empty
Shino response isWould certainly be better, ^
The line is often not positive. And
Sometimes they hurt durability.
ValvesAnd 2 X The valves Gu WebmasterNo AgeGu1When Ratsupu,Si
In one Linda!: 1 丨 cart: we lag cow, the Yoritaku
Output by inhalation of a mixture of I 1:
Dyeing is the benefit of one of his muffler Geru '. And
It marks the way a set of exhaust from each cylinder SuTsu
Results of the engine is: will change the rating.
Waste ^) II is about the power, of everything Oh
Etc. does not clear as calculated for Ru
实際 should say that, that is. Approximate number of coastal
And based on extensive test data, and Ekizo
The Sutomafura
Form the Ku Kimatsu
What is Ru. Until
Temperature of intake from Ta 积
To the genesis and progress of the exhaust
That they captured Ke Le
ば, the present, when the ni Performance
Lead up
What is not
I can go.
V? II400II 尺
Of II 11 (3 Ekizo made
- Muffler strike,
1 in 4,111,102 协 II
V?1A replica '.
Falcon 8 の 方,; fu ga smallIn
V 4Set of engine exhaust, Yun ^) who2# Inline4Slightly compared to those of the engine - butDeFree (; Thurs collection of parts made kit1S''
Muffler, depending on the maneuverability of a pipe to strike one Ekizo ingenuity, has been matched with a compact body Iri. Ri ^ ^ Hyun Gu power
Su Bok Ekizo one pipe. Muffler
0 foil shape of the engine changes
Fee 贞効 Lee 丨 to: Gadget Geru; ^ as flame 'Ware ~ exhaust
Emissions by 卞Jiru guy in quotation). ! !) And interest in limiting the large
; 丨] there is a. Shelf 丨 II] I 0 state is the number of rolling
What is the condition for different times in the race to emergency
Can hoodwink the 設足 济 及 of Castle ÇÐ translocation system,
High output power - be. AlsoEach systemGermany's Lindner
Exhaust of Ma 广 "desk / /: de in - we are Wataru, then the exhaust
Ru 丨丨 from each cylinder; by force, IX Bar
4 In 1110
And rather
4 1010 2 40 In
Shelf life, especially in low-或 Yu Yu
The ulnar
The high013In 或4丨II
10 Inと を were ru the same.
4 11110 2
Inline4In ^0In
Used! ^ Dissemination:IX’
±31TempleInStudents に は4 111(0
2(0 InAs low! ^ 或
Considered superior,
Ding Yang-ship 0 8 0
Ii
Mixture-do engine puts in at the turn into gear as requested. But it is most difficult
KyaburetaThe ーGiven the role
Carburetor will say a word, "Gasoline
Instrumentation necessary to create an explosive mixture of the engine
Prefix "That's. "What 簡単Ji force or not. 思 and
U might be some people, that this simple! :
16In order to have the various parts.
Main jet ginseng: open throttle; 以 鄉也 1:
Necessary to control the supply of gasoline. Carrier Keihin
No. Bureta of the main jet is the diameter table
Su "100 1 1 1 ^ # 02 is 102 and thigh). Large number of second
Well Kiku 'is a mixture to thicken.
Di ginsengEtsuTony dollars: one dollar GETS DTsuトの中
The I: to control the speed ratio 浞介 from the de 屮速.
Setting, the V-de II400IIXIf diEtsu
Tony dollars^ ^ Te and the thickness itself and1Padres
- To change the close.
Needle Jet Report: controlled by main jet
If the throttle opening is more gasoline
I Jettoni this in combination with one dollar to control 丨丨].
Bok Ro jet 眷 1: 1 slot idle boy
To control the flow of gasoline at a deer 缺 Torr less developed.
Ginseng ETAjetto: Donore JettoniHomeNoreda
Air supply, suitable for air 丨丨 棍合:Hakaru the north.
1 chestnut Na bore carburetor air ~ | in the law.
參パイLotScrew: System Slow: ^ 众 丨足 of
Adjust the amount of care. And mixture is a thin, tight 込Mu
00
V DE 1140011 is (: one employs Makyabureta
Being. Bore the main server 彻], Tafuraibanre
Probe (throttle valve) I decided to 腳別 the
What is the cylinder, a negative one; tell the king, Bar So
It's down to the Kyumupisuton. Sudden
对染 Surotsutono to work,VacuumThe Bisuton
Negative pressure cylinder 1 / ^ ^ for you, Tatsuno also
Rather not save any opened, there is a good Kki advantage.
DE 3 Production Co., and for Se KushonresuTsuTay
Ngu, when the advance, In the air intake 宭胃
Na-1 air-1 for over-chestnut is an inspiratory resistance and
Since Ru is willing to remove the air of minutes
Basin:
1 1 Su Bae, who has also kept the air cleaner without removing,
The setting is beating 出ShiyasuInAnd, from one point of the temple sealing Kyabureta
雕丨 have been 繊] ^! ^ You mad, and outIn. Man Ke should avoid the riff
Feel increasingly 況合 缝 ^? 'The head to be Ku
Put 作楽 want to start from. The Cleaner
1Also remove the element, ChristoNabesu
And Su off the yarn is Jioufen turnip between the ribs! 丨 1: a hole of
Can not open it. The turbulent flow of air
Settings are gone. There.
InEach jet ^? ) Scope for the throttle opening
Tri Jettoni 奶 1
Te a バ ー, myeloid
1 1 奶 Jettoni Totsu
'~ 1 -' Straight ㈣
Su 0 - 丄 Jietsuto |
3 (all closed)
1/4
Ro
:(Flat)
Torr
When the carburetor settings for each pageInKind of Tto ^!? 8 thinking, etc.
JiEtsu柏Ru whether to change the fastest in the cart. Easy diEtsuExchange cart is
Two will be more than one carburetor,
It is important to take the tuning
Remove the air cleaner is not one based
现山 is another. Items 1 to 1 for each cylinder
Time, this tally to four carburetor 曾十 one case
10 - ^, so that the Su 丨古 丨定, removing this
By tuning the link! !) And they would,
One of four Kyabureta | 丨; one or upset the tone
I said.
SiResetNgダーが4OneThat there is, each
Sum engine horsepower is to play well each 诚 乂
- But that turns the lens. But the tuning mania
The carburetor will be four 雜 Tsumoaru line with the maneuverability of the link.驻 same pot
As in the case of the power-down to tamper with the threaded 醒 blindly stumble.
What they and each of the cylinder vendor vendor
People, and the overall attitude of 笼 Shimatsu the Wow power
Engine and 'performance; ^ Un lead to, grind
May even fall to the durability. It'll
Is required by one cylinder;! ^ Compared with the same amount of mixed
Between the tone, it means that I'll send a care intervention.
No. 2 carburetor carburetor is the same. Same 勵 Moshimo? Wang Tta
The two fat Kiyu Bruno Kiyafureta let the other one is a second carburetor
- When should give the tune one without a tar Mume丨;In; ThrottleBruno, '
'^ ^ Light leaking from the valves! 751: If there are ways to take aim at the body fiend ^
The maintenance of other machineKyabure
Repeating the desorption of tar, the handling is
What may come to agree with them. PERTH,
Tar Mume have one queue I, it is no problem
But without the hand, And the tuning on the fly
I take Narana I, when the first Kyabure
Remove the tar, put de Surottonorewaiya
No. 2 cylinder have plenty of RAM, one of Kyabure
Light from the direction toward the port side of the tar inhaled
In Downward, stop turning the screw,
Let direction is idling (Surottonoreba
Direction valves open) to give up. And peek
To be the same amount of Kino Hikaru, link tuning
Loosen the screw - that, in that 応置
- Loss also remember that there is no ash 去.
Before Setsutingu
It is useful to know
V 4 per cylinder layout that! "斯系. Arsenate
V carburetor into the valley of the bank is the position they
Ru. Jet setting for the kind ^ ^
To the critical work 赌 the carburetor
A business. It learns the ropes a bit, Sum 1
The Size] ^ # will be able to.
Desorption is warm and smooth ^ ^ that line after the system is
Eru. Insulator (carburetor and intake
CareManiHomeConnecting each trace.Rubber tube) and the 柔Kaku
Ru it. So, stop the insulator
Loosen the money set Ndo, Nave 1 1 chestnut
Riyaba to archiving on an angle on the argument forward with the link
Geru and off easily. Wear ^ "The CFC
Tobanku Riyaba side push ahead, Lee 侧 link
Equipped with an opening angle rather than Nshureta
Li5Every shift to look to put it on the rear
丄In1 --
Tightening band Inshure evening.
Figure 扯 the carburetor) ^ indicate the law. If you remove or upward, but downward
Shows with each taking [仿. Band is one evening Inshure Inshure
Think of power to supplement power crackdown 偫Tsu rubber tar itself. Amariki
Take ^) put '^ (or until, and also occur if too ^ ^ crackdown.
' "In the engine of one side of the 侧 Kyabureta link
XuIn^Tar force devoted to one? What 钱 Aid fromTsuAnd
When people power, the carburetor is shot in. V
Questions should fit into the Valley of the bank.
1 Inshure 丨 the tar and then |: Le Kim is 4 ^ Me,
But put the Ndo Cheer Me, too strongly crackdown Su
Giruto, 丨入 of insulator] side Kyabure
丨丨 the manifold and tar! ] Gap 入Rikon the question
Would hinder the smooth flow of guy 浞介
ので魁〗:.总だ。
Bakyumupisuton the carburetor is low
Akatsuki in order to better 速Kara, 腊製 tree
Adopting a river, and I have 較蚨 What 丨 of Lyon. Pregnancy body 11 trees
、つレブ
Bureto
DiInBaki and Ttonidoru
Yu 颜 with one Mubisudono
Sutenresuwatsu intervene
Shah (setting 夂
Tree lights and parts for metal fittings
14 to 0 effect of hair Bisuton
To prevent would
Ha - one of Tsu. Ke 舰寸
When Ru is that people always.
Nu
Á],; Su] "^ because of, the Padres' sliding of Kyumupisuton
励面 also gone dull, it is also a desk a bottle
Themed Question 胁性 any way without works is useless and the bad.
Di1 EtsutoniBakyu dollarsMuPistons
込Mu when it is dark blue, stainless steel washers must
That the people in question. This setting, par -
Tsu rather than the wear of 丨言 Kyumupisuton Gu Bruno
Tsu because one can always put structure for Pacific. Until
た、ジェTsuDollar down on Tony valve
The inside of the fixed pre-trained and one cart. Bar
Kyu Mubisuton the base of one: in place of Avery
Clock 0 Ri [B 1 can be mounted on Su. Remove
When will I be turned in reverse. Jetトニ一ドルの
If you get a flat and needle-tae from the ~ Æ "-shaped hole:; two enterprises
If they tied firmly seated
Ru. This is a handy box wrench in Translation 8.
Basic Settings
Setting, the @ and not required for a
DO NOT TOUCH around blindly, but will assume
(1 screw 闢調, Bruno "Ista - data - 閫調 services,
Eakurinabesu tightening screws, pie
Rottosukuryu one position of the tubes). Each system
Degradation and lead to a change in one of 燃調 Linda.
Getting and setting the example Bruno
Alms to the Mal setting one of eight states
Cod, 8, no test before setting it
Malware from 8 give back to the state, and I say
U want to go. If there is no oblique 转 be reset, and 8
And knowing that you are 8 or better
What is often because they ship.
Cab - LESData一セッTeingu, doesSlot
Gasoline is approximately4Pi0Professor Chu is a charm about6Pi (; to appreciate the.InThis engine is a tree
Flows ㈣ cart engines in 1 ^) in Me Rareyasu Kwon, - the travel! Is required; '
A key question will Nollet degree. Opening X
Su Pai power from the gas when the lightLockTosukuriyu
- Try to loosen it that way. This
Riders now 0 for how much running in the opening minutes
Need to check that. To flat
If not are you going to be, Meinji
The Bok Etsu. Symptoms such as if you are well
They. Mark of unfamiliar Surottonoregurippu
Keep one's hope.
The place to start intervention setting, the data itself
I think from the proper setting as 裉 & 5
It is to the original 则 they from Me. Serra too sea
Shooting is ㈨ 拟 but prone to trouble.
In particular, the intervention 初心Re place is a little dark 見U:
With injury so hard, knowing the symptoms of a thin dark
Because, first, I think it's best to set 丨 4 minutes
From Tingu, late, or anything from five to 10 济则 祁
Explore. The first and the second dark 丨 If the 'all of 丨分
Ku 以 than when setting the strike, More
Explore the dark (to 支勒 诎Ru on mileage). This
Time! What is interest in collecting the data for later and keep Nide 1) "can.
And the setting is changed 于節 Su
Ru.邓本 is 濃Ime the winter, is 薄Meda 议.
The carburetor is one very cart 础変 Flows';
Bok is a point.沸Tou in gasoline by about 60
And, depending on its vapor pressure of the text box until ㈣
Start the intake manifold until the guru
Becomes difficult.跑变 line warm-ups
Tta after the de-S by the heat from the engine
Roth Yasu Mari rooms 膽 I ", but be aware.
The air entering the carburetor, Chiayi 1; increases the degree
I can only pay attention to. Same air
Even with my volume, low-M & ^ Ge Wataru Ito after the stomach
Ku become. Heat from Rajeta "enter the wind
愫 data should avoid.
They also die down the heat sink of the combustion chamber to ignite the mixture alone. Check it burned so important
Mixture combustion state
Can you tell me it's a plug
Les is one spark plug for Shingumashin 浞
Aiki, not only ignite a combustion 'heat 书
To have a feature that, once the nail is needed
This should be great.
V the spark plug 1140011X 卩 ,11017-9,
11017-10 are two sets of type (1 Bae
Su 0 8 2 free car 』). Both poles Port Ho 瞧 1.5
Les was lower in one Shingupuragu etc., that it fine
Effective disaster in self-learning as chestnut, turnip
Difficult to force Ri? Be raised.
I kit (8-class international)! 』) And Gong Bisuton of
When incorporating the rod is one bra Marcello Bruno
Gu is so useless, and 必炎 attention.
Ordinary four-stroke cycle is about two plug
Be covered in the sticky should not. If
Plug, if it is sticky, and Bafurebu 'Department
The E-phase system after burn 粮!; The noodles and
Is rough. ^ ^; - The
Motta has burned to white. Translation slope Fri color
Lee has a wear strength carbon dimension. Woven plug
Big bad track aru の て -; mirror
A burnt so. - Is) and the absolute
Sculpture is a dynamic foxes, they pale gray tan
That. The Kim Bong Hazime Tsutomu 欺端 and even depression
State cases are wearing dimension Kyabusetsutein 0
Clock and the Padres are going horse! &
Possible oil leaks in minutes.
At room temperature in 9 roots I 丨!〗 Should be fit for summer
1 to JOH) 丨] that good. However, 以 it I: a
If you use some of the potential duty Su 浞介 too thin.
Battery,
Aptitude fire plug
^ 0 and give the flowers
Contributes to the role
That. Plug 'to
Spending and concurrent care
To battery
Also note Haraita
But potato. Klein
Cub Tta smoldering: | 纖 strike is this one
Cart cart will be all that is not all about first.
Carbon force5! If you wear dimension
Also considered good smoldering
Since Ru, checkTo explore,
8 for the Su-mi 成Ra Kumasu (: generators - the tar
And take off, this is no longer charging Tteri ^ ^ 1.
Before the race, even if it is fully charged, les
Su is the voltage after they fell to digging 变. One
This means the battery is repeatedly charged and discharged
It is not. Battery 1 is also wildlife, old
And voltage drop will be faster. So one les Su ago
のバッTerry ^ ^ is one kitchen and we want
It's.
Voltage is the engine when you are around, that
沏 when you are hanging a load on the engine Ru 1.
The lower voltage at high-speed negative 3,4,5,6
Growth slowed down in the rotation of the rotation Tokino Takashi cargo area,
Deteriorate the response.
11V battery and one power of the 压 切Ttara the
溯 Omotsu said it may charge. Bar, 1 power of Tsuteri
Pressure is at the start of lap 13 and even Ma
While not a punch line to get around 12 Ma.
Funore Tsuka is also one Ratsupu Batsuteri charge anything,
And just before you get nervous before the race and test Bok
Would never. Also, one of the new Bruno Tteri Gu
Se 啦 cart always be set aside as a spare
But what you want it '.
Rajeta is not just a radiator. It holds the key to keep power up and power
The only bad luck is Rajeta
Consider the way through and around the wind
Rajeta is literally one role ^ ^ water discharge
Heat emitted from the engine that has been robbed 循還
Original one that I'll Rajeta: 88 / etc..
Benefits of water with two engines to the ordinance
It is difficult to place such as wind, cold
Let it be cooled by circulating the 却水
Ru can be cited. In other words, the cold wind driving
Hard part, but even to retirement, Uota
20
Wrapped in one jacket to do
So I tried a locally
I'm going to be cool - "I become capability.
Of combustion and also 审 Watari Watari & control
No snow, so Ru Roberts, knocking resistance
And sex, detonation (燃娥 Atae Hisashi)
For such higher limits, it
With the, you can set a high 匕,
Be easily powered up.
Also, the water around the port 贴
| So be cool, dense air
1 degree higher, one need to Appu Pawa
Required efficiency (strictly speaking: ^ efficiency)
We can also expect improved.
Bok took the Saburajeta Kit
Su, on the ^ ^ double-digit capacity of about 1 Rajieta
31/11 will 20,0001 ^. The IIV
? Roughly equivalent to a capacity of 400. The option
Set air duct parts (KyaburetaTo ー
Aluminum box! Entrance polypropylene with anti-^
III
Bankrupt, had bad until ㈣ Fuin, Raj;!: Tar and
And (^ neglect of 轻. Fuin crushed the system that go beyond polite ^ (Natai.
Jinheddokaba) by build up,
Radialェタ一The flashes of heat flow from the carburetor
To prevent it in a particular sub-Meinrajeta and
丨 of Rajeta 1 |! ] To get out of the wind, the Kiwamu Tamotsu Laget
One can fool the cooling data, the cooling efficiency
Up. Especially in the summer and out of the race
If you're thinking Saburajeta field is essential
And say they are now.
Cooling efficiency of up to 1 Rajeta
Way, the water cooling ^; will be resisted
Mosutatto will probably want to remove the server.
However, by this ^ ^ 拟去 self, and the
From no longer made,
Note the water temperature is always changing
Meaning they can pay '. Also
If the cold period, over
I tend to be cool
Disconnect the server Mosutatsu Bok
If Ta is a tape
Rajeta theThe ー貼るこ
And the 交力 Yes! ^ Narrow the product
Corresponding to Ku.
Conversely, the Rajeta
Traveling フ イ ン が 中 の Xiaoshi
That in such a jam
Once discovered, Gu Bruno dry
Rajetakyappuvu))!
^ ^ Seedlings in Rajeta! ^ There is pressure
Ivy & radio 汰 to:In: One evening Kyabbu0We 閙 RebukaIn, Its pressure! ! ^ Is
Certifying export documents. As a cap (? ^ To the.
And. Through the crushed remains of the wind and I Fuin
From part 1 Hana Sono 果Sa Rajieta features
Because they will '.
After one Rajieta 組Mikomi 眷打; us Wed
And one [? And "InKe Yaruji Saburajieta one dimension of the system, server capacity, "which 词 and cheeks.
To get the best engine performance, selection and maintenance of oil is the key
Suited to the characteristics of the engine oil?
U 逍 a guy who is often the engine tuning
The people 试 U 逍 a profit out of oil is low. Force
One shop and go | |; | Burandooi name outside Ida
Many are 販必 Nollet.
TheseSai LeeLE is a single GraceDo,Ma
De Ruchigure 1, de 3 kg, 5 2 Haipafuo class
- And so Mansuoiru. However, one
Hu also Mun four-wheel 丨] or that, in place, the engine of the Yodo
Padres] is something that is as Makoto Takashi. But
Various additives and blended What | The 丨丨 诵丨
That is, it is good for certain engines
才イノ^;Whether there is a doubt |! I 1].
『斯系 Oinore engine of the human blood
Similar to that between the clerk. Q Again, people, their 丨 'of 丨身
LES blood I still have one good match, should be. D
Again, engines, engine Tomoi growth stage Provisions
Les from the time of the test machine development arms 丨阳 Ubeki] developed at
The only old Besutoma Inore
Tchinda 'should you / us.
Puff best engine
丨 come out reset the Omansu
To ho, was developed
Ultra pure vendors 丨丨 M 0?
Oil, organic Moribu
Yuanmou rub 搬剤 Garden (de.
Add ⑷ を し た Dian Grade
Ino 卩才 8 ^, Furiku
A reduced output Shon
ッ プ (same pang で about 3
? 6 improved) 冋転 Aidoru
Number, compared to commercial
400-500 I” Pablo nails assay
Pu and idling
Up from this very high rotation
Eggplant.
Spring VPlant Groups Tips400^Il-year-old route map
By carefully 見Ruru oil
Come to know the tone of the engine.
The same goes for any engine is the consumption of oil
Check the amount of expenses that the main engine
The Tenansu ^: at, there. Driving all before the age Inorere
If you have to check the LE is strictly
Not the norm. Bamboo consumption check
Let 惯.
First, always the same attitude from the machine
Bruno all the les les "^ Ru. I put the stand condition,
State either stand vertically without
After that decision saying the oil gauge 1 "measurement. 丨丨 of time!] Have
They see the oil gauge is the number after 10 laps,
If the oil level 丨丨 original intuition, distance running
Oy per GmXiao gariI can calculate the amount of expensesBeast.
Lap at the time (distance) of the Oinore ^; II to 缺
Do not forget to take the data to accurately measure.
The race is the amount of expenses this Oinoba especially Xiao
Su Au Zen power so that you know, make sure to calculate
Enjinoiru is the same as human blood Toi
By U, if 兌Re the oil, the engine
The conditions there - shows up. Resona
Also to know is, every fire basting with oil 丨 丨 Ji-propelled Russia
Oinore Kondishiyon of this check is
The size and try to 惯.
对 this to be one of the consistently best
The Enjinoinore of Kondishiyon; [your state dog
If E Oke and mother, the engine power to the anomalies5'あ っ た 丨 丨 help
Will notice the change of oil. Something is wrong place
If discoloration of the oil, if that's fine cat What 诚 Fri
The book is written well and there. However, this
The book is ^! And examples, each one oil "| to pull out
汽慣 By integrating the solution even after reading the book profit
I seem unable to experience a subtle change
U should be. Such ^: Nan Maintainer
Su ability to do5- A large Torapunore - prevent
粒Tsu especially not to say that.
Usual clutch is smooth
Multi 版式 clutch car clutch ^ ^ Su Bae 1
Use the river intact. Capacity versus the power-up
Have also been de-minute things. Half clock loud
报作 unless the latch Furikushonde
IsukuWare ofLee came, came in one 起Korana.
Bomber 及 丨丨 pretend to comb the three Ndeisuku, Ku 识化 蛏
妝 is that if one is not 丨丨 thigh. However, this
议化 original clutch and the proceeds of the ㈨
Since Ru, Gu checks and Nollet Ohno 1 to 1 of Ho 记期
People that clock - it Ming. Especially race 办紅
The potassium load on the clutch 熱Re 1 -: always greater
Want to know that.
As I felt the 揽 沿Ri field data of the intervention,Clock
Tears spring latchShaBite the one we ー 10:
Power I "that there is a way Deru, cut the clutch
When spring, but, TONG I 丨 I! Or to lock,
I would also difficult mission as the original Ho trouble.
', FurikuYo SiHiroki Npure ㈣ to cart 1 is the engine oil 込Mu ^; a row while
22 U. However, molybdenum is using the oil should not be too slippery.
M
Kuratchiautarika &
11758 ^ ^ This Narutata concave or
Auta find the ㈣
There. Kuratchire
No slipping from the Ming Rica.
Rear hopping downshift 丨丨 拟
Is idling about 3,000 to 111 卬
Oko la Ete a hard time out and party.
Bok built Misshiyonkitsu
乂卩! Free 仄 Toransumisshonkitsu of 1400
Cart the main shaft (with bearings), May
Nshafuto side 2 - 3 - 4 gear counter
1,2,3,6-side surface and one gear shaft
Clip is 撤戊. Remaining counts
Tashafuto side of the main shaft 5,61
The wave of color and 4,5 counter shaft
Bruno Section of the car washers are based. The one Tsu? ^ To.
Partner during the mission, each par -
份札 in Tsu (aka F) Tadashi been viewed. Ke order for take:
To verify. Knowledge of gear-tae, a similar
I said 沉乱 avoid missing so that the glue. Force
Kind and error, place the washer;? 汰这 to come and Dori
Want.
Dropping 0 ⑶ & Ding Ding Shan Kwan 3 Hidden 3101 \ 1
Knowledge of power transmission 100 rear tire, take the gear ratios, and their most susceptible
Yarn it 丨 II mission: they clog, the mission
I b I 丨 the old file while the viscosity molybdenum 'After a minute
The cloth. Or even one shift fork Moribu Kara
To 維布 Dengurisu firmly. The Cow
Takashi printer shaft 1] 1 B of the gear carefully, especially
Have considered. This (? ^ 丨 Mushifutofoku wings is required to be vertical.
After that the cloth. Russia has one gear and gear other than
And, large gears and shafts Lin 励謎 桕対
Because they. Order to be well familiar with the initial oil -
Work needed to made a better film: ^ it.
Misshiyon II crank case spotted
After that, it must be rotated by hand, Shifutoreba
- Move the gear shift smoothly
Washer (^ 胁付 1; ^ (gear position to the side length has been rounded corners;! To
Moments 扣尤 顿 Shinano nothing new cut-Ke 懒 swop the circlip.
II
Netherlands 1
Suburain (?) & & Sakuribbu toI、B ^8Let. Sirk1) Ffu
Gravity load and 005 bills still widely Ke ^ 4 龄 it was difficult to disintegrate.
- Circlip
Nakurippu is 友Ki specimens (驶 ^? Become rounded. This burden also
Widely considered to be under the prefix, and hunger and want.
To check whether.
The Pacific Cup U mission when the system
If Futofoku and Atari, the pitch of gear surface
Ia and the non-camming and gearing Idabo the Name of God
长饩 丨 the system too much:. Pay for gain. Sumu
Size 视作 and shift the gear to prevent missing
Forget it all means is not '.
-Over of the mission, go to Le Ho 1 1,
Bi pair people: I work place, washer and color '赁
If you do not need to replace the internal friction is less or are
Is not brand new circlip to be sure? ^ To
Be. Parts have always been a load of gear
... That power. Therefore, Akiyuki. To put it in position 截To
Note that. A load greater than the area
Yarn is considered healing to take to find Kiku II Su
Ru. Small parts that can not be neglected.
Mission gear, and inspection, Dubbo's Name (to be rounded edges) were
They, ki: ^ 饿 also be required to request for the deserted, even in the face D Bitchingu 丨 Gear
Do. Resona from pitching and the lack of gear) and it will,
Then that too is no per check.
Speed diagram depicts
Consider the gear ratios
V de Kurosumisshonki II40011X 6 speed
And the 組Mikomu Tto, # of A ^ 11: 匕 is one B
Gear 2.667 (Takumi / Akiyuki), 2 1.941 (mouth /
33], 3-speed 1.667 (21/35 ", 4-speed 1.478 (237
34 ", 5-speed 1.333 (24/32", 6-speed 1.231 (267
32 "will.
The gear ratios would be applied to core support kit for each one
When Ru, mission] V [ 』Bruno-de-approved," Tsu only one
To not work, change the ratio, the ugly dry
The Bok and Doribunsupuroketto Fuai Puroketsu
2 Nanorereshiota mud - 匕), and, to be
Is.
The gear ratios in ㈣
Is expected to draw a line speed 闐
Ru hope. Engine in
Ng I "when the number of bottles, each
Power hour on the gear5^! 11 / cart
To find out whether
Gu's, it's a rough ', the speed
Schiff Tsu 丨 丨 by drawing a line
Toappu, Dow shift
Icon when the engine rotation
You can know the bottom
Ru.
Now, car] III, but to draw the figure, the following equation
Of a good ^]: adapt to just come in 匕.
If you want to know the speed of 10,000 at 叩血,
Ding2^10,。00FineAll so-called
Ding! "Is the radius of the outer tire (melon). 况6Once the engine is
Translocation (叩爪). 1 ^? M of A - in 匕, one mud) ^!
A father of Beidi Hi ^; 匕 Fainano Ge X represents.
14 丁To 15 Doraibusupuroketto Ding, Dori
Bunsupuroketto has been 薏 41-48 for the Street
I! ). 15 of 44 from which a combination of Ding Ding
And with a slick 18-inch rear
Put to the outer radius of 0.318111 as car
- Figure on the right looks like.
Sodo free line speed 鲁 囡 卩車 400 (embedded 囿 mission kit, 15-44 in the Final
This way - one of the Mun Su Bae: "^ ^ 12, it depicts the
And Ru, more power 丨 Mission Kit5Line spacing
I feel that small: it should take.而 force ^! Sum to 1
Size and to, over, to prevent one Reb.
Fuaina / ^ ratio on each server - stress the Kitsuto
Top gear - and how 独Ru the end of the cart,
Specific to one particular corner of gear (eg: 2-speed) to
# There is a way Ru.兑Ru or both of the effective
Car - to take advantage of the picture. However 痴皮 Sakitsu
Bok Bok is short so do not use a six-speed storage.
Patrol 8 ku 2 ひ バ - Continued
Doraibusupuroketto is 丨 4-15 Ding, Ding Doribunsuburoketsuto will be 41-48.
0 叩01\1 糊 18
Bruno, Ino, "Spend more polished performance [
International public class with キ ッ に は Bu
Chi on titanium parts
As river machine Kimi Tooru Honda 'Power5^? Techno
Logie questions triggered the introduction of V-de-1140011 / 2
The Reshingumashinma? 1140011 change to Measure
貌 kit to make the optional parts
II110; put all the tips so far
Been developed.
Now, once a major part of development? Weaving the international 8
I made the kit as a Class IX 甸 Ke valve
36Titanium connecting rods and the use of ^ ^ in
There is. Due to this, the par-head around
Tsu (the valve seat ring) titanium valves
Tuned up to consider the suitability of materials and chemistry.
Density of titanium is 4 丨 4 8 / ... steel and about 609 ^
In that light, that this even better
In recent years, LES 1 Thing "as the old machine 桌呀
Is attention. But processing titanium Mu
Common sense and that is highly volatile Kos Zu Bok
The Ru,IIII0 new processing method that was developed in
More titanium parts at low cost - can
Now.
⑩
Forge a more direct Sutekiyafureta evening latching brake "^; Corporation? Aluminum to ^ ^IIAnd plate; ^ Co. 411 system offers a hose around the jaw when one took a breather
NresumesshuburekihoSu.- Boripuropiren Ddokano made to improve the engine, '1. Prevent a Tankuburiza cod1Setsuto.
Greater kit / "Tsuguopushon 1 /" 1 Tsu list
KitCartParts
JiniazonoisuWith
Viii - Magic D
8 for International class
BuXI D
Optional parts
Junior - for the Novice
D
Yan-level probe by State
卜!^ 丁
Camshaft
〇
〇
1 cylinder head
Piston
〇
Titanium valves
561
Links piston '
〇
Bruno "Rebusupuringuritena 1
1
Conrod
〇
Evening Saburaje1
〇
〇
Tofunsumisshon
〇
〇
Furontokaunore
Kyabusettingupatsu
HadXMuffler
〇
〇
〇
〇
Screen
Shitokauru
〇
561
In 561
Riyakusshonsupuringu
10
Riyakusshonburaketto
1561
Doraibusupuroketto
〇
〇
Doribunsupuroketto
0
0
1 set Sutearingudanpa
0
0
1 hose Briza361
〇
〇
Furontoburekihosu561
〇
〇
Chain Drive
0
〇
Eadakuto361
〇
〇
1 Fyuerutankuburiza561
〇
〇
Wire harness
〇
^〇
Kometa evening / \ 5 5 Ah
〇
※ table の〇宠 investment has been marked as a kit and options. The drive, Doribunsuburoketto, Doraibuchi;!: Please replace the set N. "
Is from Ru.
[0 户 户 [etc.: Bomber
It's Setteingu
Soaked with oil and
Seo Engine 4
Is
Some of the potato.
Jobs
1
But a lock.
ソド円に
Ru.
Sub-function called
Gear system adopted
Ru.
Sail de
That.
Become something.
Four-cycle engine
So it '.
呼ぶ。
ムだ。
Skip down to do it.
De 誦册 0 ^ 7 ^ 00
Head around
OhAnd Barappu呼ぶ。
Timing "engines O
Is a large burlap
Taken. All these
Be. FREE pop-key
Tto (Novice 'ju
For Nia) is the,
回Seru it.
Because they.
Cylinder
Piston Ring
^ ^ I have to Bae.
Think である.
He enthuses, crank
Conrod
1 In1/‘Reset
00
Note し た い.
で削る。
The Sutomafura
Form the Ku Kimatsu
What is Ru. Until
Lead up
What is not
I can go.
V? II400II 尺
- Muffler strike,
1 in 4,111,102 协 II
V?1A replica '.
4 In 1110
And rather
4 1010 2 40 In
The ulnar
The high013In 或4丨II
4 11110 2
Inline4In ^0In
2(0 InAs low! ^ 或
Ii
00
Basin:
Tri Jettoni 奶 1
Te a バ ー, myeloid
1 1 奶 Jettoni Totsu
'~ 1 -' Straight ㈣
Su 0 - 丄 Jietsuto |
3 (all closed)
1/4
Ro
:(Flat)
Torr
I said.
Before Setsutingu
丄In1 --
ので魁〗:.总だ。
、つレブ
Bureto
Shah (setting 夂
To prevent would
Nu
Basic Settings
Keep one's hope.
Battery,
Aptitude fire plug
That. Plug 'to
To battery
Also note Haraita
But potato. Klein
It's.
20
III
I tend to be cool
If Ta is a tape
Rajeta theThe ー貼るこ
That in such a jam
Rajetakyappuvu))!
Many are 販必 Nollet.
Puff best engine
Oil, organic Moribu
Ino 卩才 8 ^, Furiku
Pu and idling
Eggplant.
Let 惯.
Want to know that.
M
Kuratchiautarika &
Auta find the ㈣
There. Kuratchire
Want.
II
Netherlands 1
- Circlip
To check whether.
32 "will.
Is.
Ru hope. Engine in
To find out whether
Toappu, Dow shift
Ru.
0 叩01\1 糊 18
Been developed.
Now.
⑩
KitCartParts
JiniazonoisuWith
Viii - Magic D
BuXI D
Optional parts
D
卜!^ 丁
Camshaft
〇
〇
1 cylinder head
Piston
〇
Titanium valves
561
Links piston '
〇
1
Conrod
〇
Evening Saburaje1
〇
〇
Tofunsumisshon
〇
〇
Furontokaunore
Kyabusettingupatsu
HadXMuffler
〇
〇
〇
〇
Screen
Shitokauru
〇
561
In 561
10
1561
Doraibusupuroketto
〇
〇
Doribunsupuroketto
0
0
0
0
1 hose Briza361
〇
〇
〇
〇
Chain Drive
0
〇
Eadakuto361
〇
〇
〇
〇
Wire harness
〇
^〇
〇
Is from Ru.
Great engrish that..
viper_biker
But the pics makes up for itCMSMJ1 wrote:Great engrish that..
Nice... btw you know thats the TT-F3 NC24 yea?
