Turning over now - wont fire
luckybiker2010
Re: Turning over now - wont fire
- Variablevalves suck
Hi Matt.luckybiker2010 wrote:I have checked it and the fuses are fine, the relay switch is working fine too, the kill switch is good as it attempts to turn over, there is no voltage getting to the coils and there is about 175 Ohm at the signal generator. Is this the problem or does it not matter?
Matt
The 400F is very different and you should have between 80 and 120 ohms at the pickup.
