NC30/ 35 OIL FILTERS WHICH ONE DO YOU USE.
jacknell
Just wondering which oil filter do you use and what you pay for them.... genuine honda or other.....
- abrmoto
Re: NC30/ 35 OIL FILTERS WHICH ONE DO YOU USE.
Only ever use genuine honda, cost about £7.50, change every other oil change and you wont have problems.
jacknell
Are right Ali you change the oil filter every other oil change... thats not to bad.
- Polisher
- Bike owned: z1000a1h, vfr800vtec, nc30,
I only ever use Genuine Honda oil filters, they're as cheap as pattern parts so its not worth doing anything less.
Change every other oil change
- force-v4
yep, genuine filters only for me too - david silvers £8 with the socket.
- Deviant400
got a K&N on mine , it has a nut on the end so you can use a socket to remove it , has a hole drilled throught the nut for a safty wire
viewtopic.php?f=62&t=27307
- monkeywithaplan
- Bike owned: NC35 and NC30
OE filters all the way.
dx400r
Hiflo Filtro - looks liike an OE one. Used em ever since I got the NC.
Yamaha o/e from a FZ6s - half height to fit with my oil cooler.
They are cheap so change it every time
- superlite
- Bike owned: TLS, LB80 x 2
Agreed. Very handy for track/race bikes. Saves a clunky hose clamp/jubilee clip. I wouldn't imagine there's any difference in performance between makes as it's not rocket science - or is itDeviant400 wrote:got a K&N on mine , it has a nut on the end so you can use a socket to remove it , has a hole drilled throught the nut for a safty wire
'Take it to the Back'
