clutch problems
matt_nc30
- Thieving Pikey Twat
- Bike owned: NC30, 2000 R1
clutch problems
have just re-newed the clutch friction plates and diaphram springs, after taking it around the block for a test ride it seems the slipper clutch does not work as it did before they were changed, is this because of the new plates/springs or because i have assembled it wrong?
thanks
thanks
Re: clutch problems
What about it does not work?
Slipping too much or too little?
matt_nc30
Re: clutch problems
rear wheel was locking up far to easy on down shifts, but it seems all good now after 100 miles lol
but the cable had to be adjusted all the way out on both the cable and the engine for the free play to be taken out, but wasnt like this with the old unit, surely it should be the other way around?
Re: clutch problems
did you measure the plates? you might have fitted a slim stack and it will only get worse..
What make was it? I had a similar experience on a set of Kyoto plates. They were cheap..and crap
hunter
Re: clutch problems
Was your clutch slipping badly before you changed it.because if it was the slipper would probably not bite the same change down.
matt_nc30
Re: clutch problems
The clutch was slipping extremely bad before it was changed.
The friction plates & the diaphram springs are both by EBC. The are twice the thickness of the old ones, they were fooked, and also the springs seemed alot thicker than the old set.
I've noticed that after coming back to the bike after a good run, the clutch cable has no free play, so im able to back it off a tiny bit, ive done this about 3 times now. Is this normal ? lol
hunter
Re: clutch problems
Sounds to me like the new plates are bedding in.
matt_nc30
Re: clutch problems
Was hoping thats all it was
Just thought it might of been the opposite
Cheers all
Cheers all
GF Racing
Re: clutch problems
Clutch pack assembled height is critical - did you measure it - have had no end of bikes in with quickly fried EBC clutches with incorrect assembled pack heights.
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
