R6 rectifier regulator on the NC...?
calirvf
Post by calirvf »
I think the rectifier regulator on my NC is bad and I wanted to see about installing a R6 unit. What modifiaction is needed if any and does any one have a picture of a installed unit they can post?
Cammo
Re: R6 rectifier regulator on the NC...?
Post by Cammo »
I put one on my nc30 in the original position, and it needs a small amount of mods to fit, probably a 15 minute job.
I filed some fins off at the back so that it clears a ridge on the subframe, and mount it using just one of the original holes (couldn't be bothered drilling another hole, and it's held firm). Chop the plug off and solder standard size (6.4mm) female spade plugs on, job done.
I can get a pic tomorrow if you need one.
calirvf
Post by calirvf »
thanks! In that case I would guess any R/R would work since modificaion of the plugs and mounting is needed.
Cammo
Post by Cammo »
Yeah I guess they might but R6 units are tried and proven, best to fix it properly the first time.
calirvf
Post by calirvf »
can you post the pics when you get the chance. :mrgreen:
Cammo
Post by Cammo »
Pics:
http://i19.photobucket.com/albums/b171/ ... CN2458.jpg
http://i19.photobucket.com/albums/b171/ ... CN2456.jpg
http://i19.photobucket.com/albums/b171/ ... CN2457.jpg
You can see where I had to file some fins to clear the subframe ridge so that it mounts flush to the subframe (important to shed heat!). The material is soft, the filing only took a few minutes.
The single bolt holds it fine.
calirvf
Post by calirvf »
Thanks stickshift! What year R6 RR? Looks like the 1st gen.
Cammo
Post by Cammo »
calirvf wrote:Thanks stickshift! What year R6 RR? Looks like the 1st gen.
I think mine is a 2003.
Early R6's (99-2001) also suffered occasional reg/rec problems, 2002 onwards is the revised unit I think.
calirvf
Post by calirvf »
Cooll... thanks ..
Delvey
Post by Delvey »
think im lucky,as mine looks like that, and is held on with pull strips
