16T, 520 pitch front sprocket
Re: 16T, 520 pitch front sprocket
I'm using a VFR sprocket. The offset is slightly different, but I have some handy washers to use as spacers.
Those little washers you use at the top and bottom of your springs in your NC29 forks come in hand for so many things. Clutch basket spacer, sprocket spacer, fork spring washer....what will it be next?
Who are you and why don't I know you? I hope you were polite enough to finish behind me at Phillip Island. Not like those rude b@stards in front like that cappa........
