SPROCKETS TO SUIT VFR400 NC30 PROARM/CB900F CONVERSION
WOODY
DEAR SIRS,
CAN ANY ONE PLEASE HELP ME ATTAINING SUITABLE SPROCKETS TO SUIT THE MOUNTING OF A VFR400 NC30 PROARM ON A 1981 HONDA CB750F?.I AM HAVING NO LUCK HERE "DOWNUNDER" FINDING ANYONE WHO CAN DO IT.THAT IS EITHER A 530 REAR SPROCKET TO SUIT THE VFR400 NC30 WHEEL ON A 525 FRONT SPROCKET TO SUIT THE CB750F?.ALSO,HAS ANYONE HAD ANY EXPERIENCE WITH DELKEVIC 17" WHEELS TO SUIT?(I.E:THE HOLES IN THE DELKEVIC WHEEL NOT ALIGNING WITH THE LUGS ON HUB?).THANX IN ADVANCE.
YOURS SINCERELY,
WOODY.
P.S.:CAN SOMEONE PLEASE ADVISE WHAT THE REAR SUSPENSION/WHEEL TRAVEL IS TOO?
YOURS SINCERELY,
WOODY.
Re: SPROCKETS TO SUIT VFR400 NC30 PROARM/CB900F CONVERSION
You can get all sizes of VFR sprockets from RB Racing in Sydney.
http://www.rbimports.com.au/" onclick="window.open(this.href);return false;
The delkevic wheels should bolt straight up to an NC30/NC35/MC28 hub, are you sure your proarm is from one of these bikes?
WOODY
DEAR DATARACER,
THANX FOR YOUR REPLY.I AM SURE THE PROARM IS FROM A NC30.I TOOK THE WHEEL & HUB TO A MOTORCYCLE ENGINEER WHO MEASURED THE DISTANCE BETWEEN THE 4 HOLES ON THE DELKEVIC WHEEL.HE ADVISED ME THAT THE HOLES IN THE DELKEVIC WHEEL AREN'T THE SAME DISTANCE APART(OR MATCH) AS THE GENUINE HONDA WHEEL OR THE PINS ON THE HUB(WHICH DO MATCH.)
- superlite
- Bike owned: TLS, LB80 x 2
Do both wheels only have one (big) hole in them and four depressions for pins on the back? As far as I know, Delkevic only make single sider rims for the models Dataracer mentioned. So chances are, if the Delkevic doesn't fit, your swingarm is off an NC24, VFR750, etc.
'Take it to the Back'
WOODY
DEAR SUPERLITE,
THE SWINGING ARM IS DEFINITELY OFF A NC30 VFR400 AND BOTH WHEELS HAVE ONE BIG HOLE & 4 DEPRESSIONS FOR PINS.THE ONLY DIFFERENCE IS THAT THE 4 DEPRESSIONS FOR PINS ON THE BACK ARE FURTHER APART ON THE DELKEVIC WHEEL THAT THE GENUINE HONDA WHEEL.THANX
Yo Woody - less of the caps please dude - you are bad on the eyes!!
Can you stick a picture up? Does the swingarm have a single or a double pinch bolt holding the hub in?
WOODY
DEAR CMSMJ1,
SINGLE.
SINGLE.
sandfish
- Bike owned: nc24, cb350sg,sv650k3
hi,
has your swing arm got a hole for the shock and one pivot bolt or has it a U shape cut out for the shock and use 2 pivot bolts
WOODY
DEAR SANDFISH,
SWINGING ARM HAS A HOLE FOR SHOCK AND HAS ONE BOLT AT BACK
sandfish
it's def not from an nc 24 then!
good luck
good luck
