Few Nc30 questions
matt_nc30
Thieving Pikey Twat
Thieving Pikey Twat
Bike owned: NC30, 2000 R1
Few Nc30 questions
Post by matt_nc30 »
hi, was wondering if anyone could tell me how hot the reg/rec gets while the bike is running. I have recently rebuilt the bike and had the bike running for the fist time over the week end. It was running for about 2 minutes and by then the reg was almost too hot to touch. I dont think its the standard honda one.
also noticed when putting the back end of the bike back to gether that one of the roller bearings on the shock linkage had completely siezed (where the shock bolts on)
is this a common fault? and has any one got a spare thats laying around i could buy? :pray:
oh and, has any one had a prob with a tyga system touching the shock?
thanks matt
alexwitham
Bike owned: 675R, GSXR6, NC30
Re: Few Nc30 questions
Post by alexwitham »
The Tyga system clears everything, comes close near the chain, and only say 3-5mm away from the shock, but nothing should touch or 'bottom out'.
The reg rec on my bikes gets too hot to touch...so think that is normal.
I have had systems also touching the linkages when the suspension is unloaded so also nothing to worry too much about unless you do a lot of jumping.. :o
matt_nc30
Thieving Pikey Twat
Thieving Pikey Twat
Post by matt_nc30 »
thanks for the replies guys. the exhaust may be just missing it by a few mm,it looks like its touching, but doesnt seem to make a noise or feel like anythings in the way when i bounce the the bike.
has any one got any knowlage on the suspension linkage?
matt
the linkages are just bushes on the 30 - I think. Take it out and you can op the centres out, relube and stick it back in.
I assume you mean the triangle linkage rather than the dog bone?
mattUKNC
Post by mattUKNC »
While it's all off, swap it for a 35 item. :up:
matt_nc30
Thieving Pikey Twat
Thieving Pikey Twat
Post by matt_nc30 »
Yeah the triangle alloy part, 2 of the rollers work and turn smoothly, (where it bolts to swingarm and dog bone) but the one where the shock bolts on wont move and looks slighlty bent, if i tighten the nut that holds the shock on as tight as its meant to be it wont move.
have had my 30 link welded and drilled for a raise ;)
fastdruid
Regular Member
Post by fastdruid »
matt_nc30 wrote:Yeah the triangle alloy part, 2 of the rollers work and turn smoothly, (where it bolts to swingarm and dog bone) but the one where the shock bolts on wont move and looks slighlty bent, if i tighten the nut that holds the shock on as tight as its meant to be it wont move.
That is correct. I made exactly the same mistake and went as far as ordering new bearings before realising I had an NC30 triangle (in an NC35).
The NC35 has three bearings, the NC30 has two and a bush. Incidentally you're meant to tighten up the shock onto the triangle so that the bush is not under stress in the normal position. As you can imagine this is a bit tricky.
An NC35 triangle mounts straight on and is much easier (and possibly better too).
Druid
matt_nc30
Thieving Pikey Twat
Thieving Pikey Twat
Post by matt_nc30 »
thanks for reply druid
have searched for a nc35 one but cant seem to find one. is it possible to replace the bush with the needle bearing from the 35. are they the same length / diameter etc.
matt
Cammo
Post by Cammo »
matt_nc30 wrote: have searched for a nc35 one but cant seem to find one. is it possible to replace the bush with the needle bearing from the 35. are they the same length / diameter etc.
I thought that Rick Oliver had roller bearings for the nc30 link available as a replacement for the bush, but I can't see them on his stock list.
Maybe send him a PM, he'll sort you out quick smart.
