Fork Protrusion Through Top Yoke
- DoktorMandrake
- Bike owned: NC35 & NC30 x3
How much should the fork stick through the top of the top yoke? I assumed as it looks like it's set that there'd be a value in the Haynes. There isn't. Just says make sure they're even.
So how many mil do you lot normally have your forks sticking through the top yoke by?
- abrmoto
Re: Fork Protrusion Through Top Yoke
Forks should be flush with top yoke, if you push them through you will smack your rad with front wheel on heavy breaking.
- DoktorMandrake
Thanks Abr! Will set them flush then. Don't like the sound of anything twatting the rad.
dr_46
i have them about 10 mm through the yoke and never had a problem i have a tiger kit on if that makes a diff...
I have them set about 5mm through to help turn in (as well as raised rear).
If you're using original bodywork then the front wheel will hit the fairing v-piece well before the radiator.
The proper sized front tyre (120/60) and firm fork springs will also help it not to hit.
