antifreeze
- Deviant400
antifreeze
just a query ,,,, after flushing rads thru need to refill with with the 50/50 mixture , but before i go buy some antifreeze any one reccomend a particular type , what do you guys use
viewtopic.php?f=62&t=27307
fixer
- Bike owned: nc30/bsab25
Re: antifreeze
I bought mine from wilkos,50/50 as usual.You can buy more expensive but that is your choice.
F I X E R
Re: antifreeze
It's not so much about price.. it's about whats in the antifreeze.
Too lazy to type.
Price isn't so much an issue just read the label and look for Silica FREE / Motorcycle / Aluminium engine stuff.
Too lazy to type.
Be careful when using anti-freeze in your motorcycle. Car anti-freeze has a silica component - which keeps car systems clean but can damage motorcycle water pumps.
Overtime the blades in the VFR pump can be eaten away by the silica (fine sand) added to car-type antifreezes, which help keep a car engine clean by polishing the insides.Always use a motorcycle type antifreeze or a car type without silicates. Some car types contain silicates that can accelerate wear on your water pump. This probably doesn't matter for dirt bikes because they just don't put on that many miles, but in a street bike it's important. Use an antifreeze designed for an aluminum engine without silicates. There are several brands on the market, just read the label. Always use distilled water, if possible. This cuts down on the buildup of mineral salts that can coat the inside of the radiator, cutting down it's efficiency. It's also a good idea to replace the hoses every couple of years they tell me but I don't think very many people do. It's still a good idea. Same with the antifreeze.
cbr400rrn
- Bike owned: NC29 CBR600F
Re: antifreeze
Or go buy ready mixed stuff from your local bike shop thats specifically for bikes
Re: antifreeze
Yep :)cbr400rrn wrote:Or go buy ready mixed stuff from your local bike shop thats specifically for bikes
For the price of the stuff, getting it from a reputable LBS will save you plenty of hassle in the long run.
Wemoto sell it for about £1.50 a litre. you only need 2 litres or so.
