fitting ram air fuek pump
Spike16
Post by Spike16 »
Hey how do i wire in a fuel pump for my new ram air kit (just arrived from dynopro racing)? their are two wires coming from the pump I assume this is a ignition live and a negative?
also is their a particular place to put these, I have mine on the right side of the rear subframe the the moment is that ok?
Re: fitting ram air fuek pump
thats where mine is, as for wires id have it at a guess that it'll be +12v ignition. I'll check for ya in a bit if ya dont get a deffinate answer.
viper_biker
Post by viper_biker »
I extended the wired and wired mine into the rear coil. Why? Because if you stack the bike, all you have to do is hit the kill switch to stop the pump from working. I housed the pump behind the fairing where my right thigh is just beside your arse. I was waiting on a moment like this to happen though,
Spike16
Post by Spike16 »
ha yeh I thought wire into the black and white ignition lives then it will be killed with the kill switch what does the other wire go to then?, think il call chris up and ask him as I really dont want that happening to me
the other wire will be earth mate
viper_biker
Chris will tell you to put it to the coils, that's where he told me.
Spike16
Post by Spike16 »
great cool so earth with one and coils (ignition live) with the other cheers guys
