GK76A Carbs....what happens when you twist the throttle... ?
Varcon
Hi guys,
Just been thinking a little bit about my carbs...and this has also sprung from when i balenced the carbs on my 600 the other day....
When you twist the throttle on the GK76A, the butterfly valve opens, but is the slider meant to move up aswell, because mine dosnt!
M1KE
Re: GK76A Carbs....what happens when you twist the throttle... ?
Not unless the engine is running/being started. The vacuum created by the running makes the slider lift.
